Tone Miser
Member
Damn - those Provincial models were godawful looking things. Like a throwback to the early 50s television set or Guild monaural Hi-Fi . I bet they barely sold any.
If you keep an eye out on e-pay you will see these are available. There's one right now titled Tektronix 311-0055-00 50 Ohm Wire Wound Potentiometer which I'm sure would work. The originals were 50 Ohms at 5 watts. Just keep looking and they will become available. The 25 Ohm pot will probably work, but I'm not real familiar with the 70D's, just the 70E's.Good afternoon,
New to British audio.
I need an opinion on pots/L pads on a set of W70D's I picked up in the past few months.
Since 50 ohm replacements don't exist I've given up looking. I have two working and two non working 50 ohm units. I have two 25 ohm units from an old pair of Fisher speakers that I was considering using as replacements rather than replacing all four with 8 ohm units. Plan to use the 50 ohms on tweeters
Just checking to see if this may present any danger/degraded output while using with tube amps?
Thanks
Assuming they can be refoamed (can they and is there a specific kit?), the current owner says “voice coils are good no rubbed” concerning that, although I don’t know what the “no rubbed” part means, wouId these be a good fit with the settup I currently have?As midrange speakers, that 8'' foam surround model came with variations. I can just distinguish The ''FS'' and that means it was fitted with nominal 15 Ohm impedance copper wire coil , a cloth dome dust cap and a corrugated cloth spider. The more common version is the Super 8/FS/AL, having an aluminium wire voice coil and an aluminium dome dust cap and originally a bakelite spider. 10 to 12 Ohm is typical for both models. Age will have effected them and rotting of the foam surround is the main problem followed by the voice coil glue failing and frayed or stiff braids.
Ok, thanks for all the info! Assuming that I can get the for sale ones working, you they make an appropriate replacement for the mids I currently have? I’m missing one of my mids currently, so am looking to replace it with a pair of new ones. The tweeters are Super 3s that test at 14 ohms and the woofers are W15s that test at 12. The one mid I currently have tests at 12 and the pair of mids I’m looking to buy test at 11.2 ohms. Would these make a good replacement without the possibility of damaging anything? I’ll attach a picture of the mid I have (labeled RM) and a picture of the mids that are for sale. Also attached will be a picture of my crossover. This is all being fed from a Technics SU-8600. Thanks a lot!Original manufacturer's repair kits for vintage Wharfedale speakers never existed. Wharfedale Wireless Works LTD. obliged owners to return a faulty speaker directly to them or their agents and this involved using a replacement cone assembly rather than fitting a replacement surround. If the cone is in good order i.e., it is not torn, creased or out of round , then surrounds can be formed from polyurethane foam sheets by marking out an annulus and cutting this out with scissors. If you are not into d.i.y. then you will have to find someone with the necessary skills to do the work for you.
Not that I'm aware of. They designed and built their own. These CTS speakers have a stamped sheet metal basket; Wharfedale woofers had cast baskets with very narrow posts to hold the magnet structure - they were way ahead of their time, realizing that the basket itself could generate reflections. These CTS speakers may have come out of Wharfedale speakers, but they were probably put in as replacements.I was given a pair of 12 inch woofers from a knowledgeable fellow who told me that they came out of some Wharfedale speakers.
The speakers are CTS.. the speaker code for CTS is 137. One woofer has the CTS label/sticker but I can't find the 137 code. The other woofer has the 137 code but no CTS label/sticker.
Did Wharfedale use CTS woofers in their vintage speakers?
Thanks for that information. That helps me out.Not that I'm aware of. They designed and built their own. These CTS speakers have a stamped sheet metal basket; Wharfedale woofers had cast baskets with very narrow posts to hold the magnet structure - they were way ahead of their time, realizing that the basket itself could generate reflections. These CTS speakers may have come out of Wharfedale speakers, but they were probably put in as replacements.
The original Linton's bass driver used Flexiprene for the "roll surround" suspension, and may not have aged well. You may be better off with the later versions that used a rubber roll surround (Linton 2 and 3). The W70's are a beast, and they all have slight variations through the years of production. If space is a consideration, look at a pair of Dovedale III's or the American equivalent the W60E.I have found a pair of "The Linton" and wonder how these would compare?
The W90s will be great. Again, a lot of minor design changes through the production run so sometimes there's no definitive answer to what is right, and also no documentation for any of these because of the fire. I would also tell you to remove the original purple jellyfish tweeters and replace them with more modern ones without changing the original mounting. New tweeters will really make a huge difference in this model as bass and mid-range is already excellent. Keep the original tweeters in case you decide to sell these later, and you can offer them as part of the sale (if wanted). As you can see from my avatar, I have the W70E models (Rosedales) with 15 inch woofers. They sound amazing, and go lower than the KLH model 5's I used to have.Thanks for all the info! Well, in the hour or so that has transpired, I have all but committed to a pair of W90s. Space is no issue, what are you thoughts on these big boys??
I just read through your thread. Super nice job. I also used the Visaton DT-94's. They sound excellent. I also kept mounting the same except my tweeters were recessed into the front baffles. I had to change the plastics on the tweeter with resin casting, and re-drill the holes to match the old pattern.
Are we to presume that you have the FS (foam surround) models and that the speakers need new surrounds? If so you will have to cut new surrounds from a foam plastic sheet as original factory replacements are non-existant. The first version of the Linton fitted the speakers internally and to remove a faulty speaker required the rear panel to be cut out.So, I have a set of Wharfedale speakers that are in a custom box. They are three way and each have a W15, a Super 8, Super 3 with HS/CR3/2 Crossovers. They had some issues, which I wont detail here and the parts are hard to find. In the meantime, I'd like to get some other speakers until I can fix my current set. Having owned these for over a decade, I guess I fancy myself a "Wharfedale Guy". I have found a pair of "The Linton" and wonder how these would compare? They are not the newer Heritage series, but the original ones. I know its kinda apples to oranges, but how are the Lintons viewed in general? Also, on the same note, how would my speakers stack up against a set of W70s? I almost pulled the trigger on a set of those, but was afraid I'd be disappointed. Thanks for any info that can be offered!
