Wharfedale Owners Thread
So I wound up getting these for a trade and had to replace the 2 purple jellies. Used the ones I bought to redo the other ones I have here. So these are a complete pair,L-Pads seem to be working fine, gave them a fresh spray. Going to still try to refinish the other pair,but at least I can try these out. They are on the floor now, just wanted to see how they'd sound off the floor. Really nice looking speakers. Is there anything to do on the cloth surrounds for the woofers for preventative maintenance? They are alnico, but it looks like the other drivers are ceramic.
How do they sound? I'm not positive, but I don't think the cloth surround had any doping on it so they should be fine as is.
Hi everybody,
it has been a while since I'm following AK and now it's time for my first post! So here I am with a pair of Wharfedale Pavarotti Project from 1990: an odd model that seems to have been sold just in Italy for a very short period. Has any of you more info about them?
Unfortunately, a midrange speaker and a tweeter of one of the loudspeakers are dead now. I don't have an idea on how to extract the speakers and try to replace them, since everything seems tightly sealed and there are no signs of screws.
Has any of you suggestions on how to take them out? The speakers look really similar (if not identical) to the ones mounted on the Wharfedale Precision series of the late 80s(like the Wharfedale 504.2, for example).
Any help would be much appreciated, thanks to all!
By looking at the images, it looks like the silver trim ring needs to be removed to expose the screws. They are probably glued on with some sort of double sided tape. If you try to remove them be very careful not to bend them if they are made out of metal.
thank you for your prompt reply! I was making some research on the web and I came across a similar disassembled tweeter: the silver trim ring seems part of the metal frame of the speaker, with the screw mounts placed in the back. Could the speaker just be glued/wedged on the front wood panel?
In that case, how would you suggest to proceed, using some warm air to soften the glue before trying to take it out?
Thanks again for all the help:)
Since these are from the 1990's you might try contacting Wharfedale for more information on them. I suppose It is possible these are glued in, but why mold in screw holes?
Did some surface surfing and found thread that might be of possible help for you.
"www.vandersteen.com"
"Ask Richard" or "ask-richard. Images are offered for the disassemble of what believe to the the same series of Wharfes that you are asking about.
Do a follow up and see if this might be an aid in your tear down project.
Good luck.
Q
Good evening everyone. I was thinking of buying a pair of the new Lintons to go with a Rega Elix-R. I have read a review where that was the test amplifier. Does anyone have any experience with that combination? If so, what are your thoughts?
Did you ever get any feedback on this question either here or in another thread? These Lintons do sound impressive on this youtube video
According to the notes, there's no subs in use. The audio you here is coming solely from these speakers.
So I had a bit of a scare with my own Wharfedale 70Es recently. I kept hearing what sounded like distortion coming from the mid driver. I took off the grill and tried to isolate where it was coming from. I found when I covered the tweeter the buzzing went away. I was perplexed because is was mid-band noise, not high enough to be the tweeter. So I thought to myself, what if the noise isn't from the driver; it could be the cabinet buzzing - and it was! Turned out that the screws on the tweeter loosened up and the noise was coming from air squeezing past the gasket on the tweeter flange. I fixed by tightening the screws - crisis averted.
No, no one on here got back to me but you. I am going to check out the video. Thank you. I am thinking hard about pulling the trigger on these through Crutchfield as their return policy seems good if they don't work for me. My local dealer just picked up Spendor, and I heard the Elix-R with their A7 2 way floorstander, and it was fantastic, especially for jazz. I stayed there for hours listening to them. Problem is at $5500 a pair they will never be in the cards. Good save on your speakers by the way. Hard to believe a loose screw can cause so much mischief.
Wharfedale W60 vs Wharfedale W/AF/1
WOW I've never seen a pair of Wharfedale W/AF/1 before. How do they sound in comparison to the W60's?
The waf/1 are higher.
Better scenery, better midrange, extended highs, deep and smooth lows.
They sound better at higher gain, the opposite of w60.
They use a W10/FSB + BR/3 tweeter.
A fullrange + tweeter is the true concept of a two-way.
A 12-inch woofer + a tweter doesn't do the same.
Hey guys, I just picked up a pair of W60D and thinking about replacing the caps. Question is, for these old speakers, what type is best? Paper and oil, regular NP from parts express, or the Daytons with a low 5%? I have a pair of W70’s I will do also once I get to them. Thanks in advance!
I would go with the Dayton 5% NP electrolytics. I don't believe the D models used oil. Mostly that was the very early series without any letter added.
@infullview ,Are the Daytons NP caps? If not, they should work fine in a speaker crossover that has old NP caps? I’m thinking of my Mach Ones that have a 33uf and a 10uf NP caps.
QUOTE="infullview, post: 14589636, member: 289647"]I would go with the Dayton 5% NP electrolytics. I don't believe the D models used oil. Mostly that was the very early series without any letter added.[/QUOTE]
Hello all,
Just picked up my first vintage system for around $160, Two Wharfedale W-70's and a Sherwood S-7100a. I've pulled apart the Sherwood and it is very clean inside. looks like someone may have already been in there to clean it up prior to my purchase. I didn't see anything that would make me question any components in there breaking down. So buttoned everything back up.
Then I opened up what I really wanted to see, the inside of the Wharfedale. There is some delamination of the cabinet on the sides towards the back of the plywood, however, some elmers wood glue and a toothpick to work it down, then a few clamps should fix that. I've only opened one side at this point, but the mid has a date of 3/66 on it and the woofer has 2/66. Looks like the mid is the alnico driver, the tweeter and woofer are not. I'd be interested in any insights that might be able to be provided. Outside rear.jpg IMG_20210228_191810462.jpg Full Inside.jpg xover cap.jpg Untouched interior.jpg Full Inside.jpg tweeter.jpg MidWoofer.jpg Woofer.jpg
Hello all,
Then I opened up what I really wanted to see, the inside of the Wharfedale. There is some delamination of the cabinet on the sides towards the back of the plywood, however, some elmers wood glue and a toothpick to work it down, then a few clamps should fix that. I've only opened one side at this point, but the mid has a date of 3/66 on it and the woofer has 2/66. Looks like the mid is the alnico driver, the tweeter and woofer are not. I'd be interested in any insights that might be able to be provided. View attachment 2148425 View attachment 2148426 View attachment 2148427 View attachment 2148428 View attachment 2148429 View attachment 2148427 View attachment 2148430 View attachment 2148431 View attachment 2148432
Your system seems well matched. The Sherwood should supply all the power you need for these speakers. Don't be too concerned that these aren't Alnico magnets. You won't hear the difference. You might want to pull the tweeter and check the surround to make sure it's OK some of these used materials that broke down over time. If the surround is bad, you can replace it with felt.
