Wharfedale Owners Thread
Sadly it is so hard to find out any info on these Wharfedales. There was supposed to have been a fire that burnt up all of these records, something I have never been able to document. But what you have is roughly equivalent to the early State side W60. I also have literature from the mid 1960’s showing a W50 a 2 Way very much like your W2. I have never seen one for sale. Make no mistake these are primo speakers. My W45’s with their re-capped crossovers are astonishing. These are 50 year old speakers!
My advice is to replace the capacitor which appears to be an 8 mF non-polarized electrolytic with a similar NPE from Mundorf. I have used the German Mundorf E-Cap Plain on several of my Wharfedale’s including the W45’s with great success, plus they will not burn out your wallet. They make an 8.2 MF 70 VDC cap which would be perfect.
Thanks transmaster, I was wondering about the actual caps to use, I have read so much about the 'secret sauce' in foil and oil filled caps selling for thousands, and others who have debunked it (very scientifically) as complete waffle. I even read somewhere one guy said " and of course the oil filled (brand name) caps respond better to against the wall placement along the meridian..." or some such nonsense. I'm sorry (and I know this will be unpopular with some) but if the difference cannot be seen on an oscilloscope it cannot be heard with the human ear!
I will try and source those mundorf caps over here from the UK. If you happen to have a link at all I will be your friend forever!
Is there a simple way to test the caps to see if they are out of spec ( I do have a multimeter) or is it best just to assume they are due to age and swap them out anyway?
The WLS/12 ' Flexiprene ' surrounds on the woofer harden up with age and the only cure is to replace them. The Fs of this woofer, when new, was around 20 Hz. There is a cylindrical mass attached to the voice coil obscured by the paper dust cap. The combination of this mass and a stiff surround can result in a crease in the cone under extreme conditions of use; the crease if it has occurred can also cause midrange distortion.
Thanks VanArn. Can I assume you have renovated one of these yourself? (how else would you know about the mass, is there a diagram or info available?)
I too have read about the 'flexiprene' surrounds, but I can find nothing contemporary about the material. Perhaps it was never a patented or registered name. If you google it now all you get is wellington boots and curable joint systems!
However, on closer inspection, I am more likely to agree with infullview's suggestion of butyl rubber, the surrounds do feel like bicycle inner tube material and are not deteriorated at all, quite the opposite, I'm astonished at the overall condition of these considering their age. I just cannot tell if the cones in the woofers are stiff or not, as I have no point of reference.
Another question... I read on some historical leaflet that these speakers may be only rated at 10-15 watts, is that true? It is a mighty big magnet (in fact it is a mighty big speaker enclosure!) for a tiny power handling.
My levels of excitement and expectation are growing rapidly now!
I have repaired many vintage Wharfedale speakers in the past and I am familiar with the Dovedale 2 system. The manufacturers could not foresee the ageing problems that befell the synthetic rubber compound used for the roll surround as the design aim was to achieve an adequate response in a relatively small enclosure. The power rating is limited as the the voice coils at that time used paper formers and cellulose adhesives. Later versions of this 12'' speaker shared co-production with LEAK models and used 2'' diameter voice coils and pure rubber surrounds.
You should have a manufacturing date written on the backside of the cone on the woofer around the edge just inside the surround.
Yes, it looks to me like it says 3/67. (see pic earlier, I don't know why I said '63, just a senior moment) Possibly in line with VanArn's explanation about later versions having rubber surrounds, which is good for me.
It also says (possibly) G/WLS/12 whatever that means. WLS- Wharfedale Loudspeaker System, 12- 12"? Perhaps G is an initial on quality control?
I am currently in the process of replacing a burned voice coil in one of my spare 15 inch woofers. These do indeed have a metal piece that is part of the voice coil and they are made out of machined aluminum. I'm not sure these would be considered weights. They are shorting rings to prevent the voice coil from being damaged if too much power is applied. When the cone bottoms out, the metal piece on the voice coil "clacks" against the top of the pole piece and makes a hell of noise, but the bottom of the voice coil does not get mushed against the magnet structure.
In 1967 they started to use butyl rubber for surrounds. But not in all cases my W45’s have doped cloth surrounds, as do the spare 10” Warfedale woofers I have in the W45’s parts stash. My W25’s, and W35’s have butyl rubber surrounds. These 2 speakers, are about 48 years old and the 8” rubber surrounds are in very good condition.
Treat them with Sonax Rubber Protectant. Sonax is used by Wilson and Dynaudio Speakers to treat their speakers surrounds when they are returned for service. It is good stuff.
Here is a site you might find handy. This is my go to source for tinsel wire. They also have voice coils.
https://thelordofbass.com/
My goodness this is getting very technical now! Just out of interest to anyone who has had to replace the caps, how did the speakers sound before you replace them? Mine sound awful! Both drivers are working but it’s all mid range and very little else! Is this a bad sign?
It could indicate that the woofer surround has hardened thus lowering efficiency and raising the resonance point. The rubber surround should be about as supple as a bicycle inner tube. A leaky crossover cap will also allow more low frequency into the mid/tweeter and give the impression of too much mid-range.
In all honesty the W60, which is the US equivalent, was not noted for being bass heavy. If the woofer is good, there are things you can do to tune up the bass such as adding acoustic insulation inside the cabinet, and tuning the port length. Depending on your electronic ability you could also modify the crossover, but it's usually a good idea to leave these old speakers as original as you can. Another option is to add an external super tweeter that sits on top of the box to improve high end definition.
The material used for the metal cylinder on the WLS12 was machined from an alloy of aluminium and zinc and it weighed approx., 26 gm. I am not sure of the exact 15'' Wharfedale model infullview is describing and I it is incorrect to assume that the metal piece is a shorting ring or an amplitude limiting device.
The exact same size piece of machined aluminum is used on two different diameter speakers and is clearly not a customized weight. This bit of metal does in fact operate exactly as I described. It probably does also have the extra added bonus of lowering the Fs of the speaker.
The 15 inch (actually closer to 14.5) woofers are in the Rosedales and also the W70E's - as far as I know the only two models of that era that had them.
In all honesty, the W60, which is the US equivalent, was not noted for being bass-heavy. If the woofer is good, there are things you can do to tune up the bass such as adding acoustic insulation inside the cabinet and tuning the port length. Depending on your electronic ability you could also modify the crossover, but it's usually a good idea to leave these old speakers as original as you can. Another option is to add an external super tweeter that sits on top of the box to improve high-end definition.
Thanks again for the info. My new capacitors will not be here for another week, but I plan to remove one from the speaker and take it for testing. I will remove the woofer to get a better idea of the stiffness of the surround. As for modifying the crossover, it is actually just a choke and a capacitor so there's not much to modify, but it must have been sufficient at the time of design (within the limits of the technology) or I can't imagine Gilbert letting it go out, him being the perfectionist that he was. I'm sure these units would have been fine-sounding speakers in their day and many say they are still up there with the best... so it's a bear hunt for me! I am capable with a soldering iron, I'm sure I can do the work if I know what is required, but I would like to keep them as original as possible.
Please let me say again, I really appreciate everyone's help. :)
Well after a long wait, my caps finally arrived from Estonia! I have just replaced them and...transformed! So this is difficult to quantify. First, it is true, they are not bass-heavy, I rather they are bass-projecting. But the bass is, well, best I can say is it has punch, and it seems omnipresent, you can't tell where it's coming from.
The presentation from these speakers is so different than I am used to. I can be pretty certain now that there is nothing wrong with the drivers. Acoustic instruments are clear, precise, and superbly staged, vocals are articulated and everywhere! Cello's and bass instruments are so powerful. (I know, I've had to pinch myself, I can't believe I'm describing a pair of speakers probably the thick end of 55 yrs old) but honestly, I found myself snooping around the sides and back of the cabs, convinced there was somehow another port or 'something' I hadn't noticed for an additional element to spew from. Very, very strange, but beautiful, just exquisite. So different from the wallowing and deep bass of the Q55's or the restrained bass of the Q35's (that's all I have to compare them with). I can feel it in my chest rather than rumbling my belly. That's obviously the difference a well-damped 12-inch driver creates.
They are definitely much more placement-critical, (which doesn't make sense, them being front-ported), but raised 10" off the ground and given some space and they come alive. And I love them.
Thanks for all the advice fellas, now explain to me why we haven't moved on in 50 years.....:dunno:
