Wharfedale Owners Thread
The Kingsdale specs as follows:
Enclosure Type Acoustic Suspension
Internal Volume 72 litres
Bass Diameter 15-inch (380 mm)
Midrange 5-inch (130 mm)
Treble 1-inch (25 mm)
Maximum Input 60 watts DIN
Input Impedance 6 Ω (nominal)
Frequency Range 25 Hz to 30 kHz
Frequency Response 40 Hz to 20 kHz ±3 dB
Crossover frequencies 700 Hz, and 3 kHz
Dimensions 620 mm × 440 mm × 350 mm
Packed Weight -
Finish Teak
You are right of course. After my last post, I did find the Kingsdale and the Rosedale. I think the Rosedale is the older model and the Kingsdale was introduced around the time of the Dovedale 3's, the ones I have found look slightly more modern. I honestly don't know why they didn't pop up in my searches earlier.
Here's an interesting note. I've been reading Briggs book on loudspeakers and found a reference which might throw some light as to why one of my woofers has been rewired (apparently) out of phase (see earlier in the thread). He makes a reference to how, once you introduce a crossover and use two drivers, experiment was often the best way to find the best sound, citing that often, wiring the two drivers out of phase produced a better sound! This sounds completely bonkers to me, but he isn't a man to take lightly so there must be something in it. I don't know if he is referring to this as a situational correction (like if the speakers cannot be faced in the same plane and one might be further away from the ear listener than the others, a sort of phase correction - he doesn't actually say why), but it's not something I've heard before. It makes me wonder if I rewire mine 'correctly it would enhance the bass or reduce it, I'm sure it must have some effect on the overall presentation. How interesting, I can feel some experiments coming on. I've yet to turn the bass drivers so I must open them up anyway, I might try that!
What are your thoughts?
By they way, those current Airedales are just drool candy! I wonder if they have 'the sound'?
The vintage Airedales are wonderful. Powered by a Rogers HG-88 tube amp 12 watts X 2. Just imagine being in that room yourself.
I think I can shed some light on this for you. When I got my Rosedales, I noticed that the woofers were wired out of phase and the other two speakers in the three way were in phase. For me this presented a huge problem because I wanted to run the Rosedales stacked on my W70Es. The W70E's drivers are all in phase so stacking them would have caused a lot of bass cancellation. I proceeded to build new crossovers which were electrically identical to my W70Es (I have an AK thread on this build if you're interested). The original crossover on the Rosedales also did not have any adjustments for mid or high like the W70Es which I also wanted. Getting back to why he changed the phase - I think this was done on the Rosedales to null some of the mid range frequencies the 5 inch had in common with the woofer to make the overall response smoother. Early Wharefdale speakers used 1st order 6db/octave crossovers. When you get to the W70E and Kingsdale you now see 2nd order 12db/octave crossovers in use and that gave them more control and predictability so out-phasing was no longer used.
Now that you mention it the Mid range and tweeters on my W35’s, and W45 are wired out of phase from the Woofer. That cased me some grief in the beginning because these speakers were ambiguously marked for polarity. I had to do the old 9 volt battery trick to scope out what was what.
I think I can shed some light on this for you. When I got my Rosedales, I noticed that the woofers were wired out of phase and the other two speakers in the three way were in phase. For me this presented a huge problem because I wanted to run the Rosedales stacked on my W70Es. .
Thanks, it is interesting. Forgive me, I can see the problem, but why would you want to run two different pairs together? Doesn't that create a complicated delivery system? I'm not a purist, whatever works for you, just interested.
It's not as difficult as it seems to do this. One preamp which feeds two separate low power stereo amps. The reason to do this? The answer in short: cleaner, more dynamic sound at higher volumes. Acoustic suspension design is nearly linear at low volumes, but as soon as you start to have a lot of speaker excursion you start to fight the spring constant inherent in this design. Springs can be modeled mathematically with the formula U=(1/2)KX^2 where U describes potential energy at some distance "X" on the spring. The speaker diaphragm is one end of the spring which is connected to the air in the sealed box which is the spring. That means it takes a lot more power to move that speaker to make a bigger wave - the net effect is you start to compress dynamics. Horn drivers like Klipsch have less of a problem with dynamics but you still have a springs inherent in the design of the speaker itself with the spider and surround attached to the cone to keep it aligned.
You get more dynamic and cleaner sound by having more surface area (more drivers) with less excursion. There are acoustic suspension sub woofers on the market that use positional feedback on the cone to insure absolute linear behavior and effectively negate the effect of the spring (check out Rythmik audio).
I think I understand. Effectively you are saying there is a premium level any cabinet can produce, after which it starts to compress due to pressure in the cab, so if you want loud and best, have two! That makes sense. I don't think I ever get that loud.
Thanks for taking the time to explain that. Interesting.
Hi all! I bought a pair of used W70s recently that need work, and I'm quickly realizing I'm out of my depth. I've read through a lot of these threads, but still don't really know where to start.
From what I can tell by the markings on the woofers, the manufacture dates are 10/61 and 2/62. All four visible drivers appear to have red alnico magnets. The two speakers have different tone controls on the back, which I thought was odd. If it helps, I'm on the East Coast USA, and the previous owner said they'd been in his family since they were made.
I obviously liked the sound enough when I auditioned them to bring them home, but now I'm noticing they're really muffled/congested on just about everything I throw at them. Additionally, one driver on one speaker is buzzing in a mid-hi frequency range. The previous owner did demo them loudly, so I can only imagine he ran them quite loud as well - hoping nothing is permanently blown (if so I definitely overpaid).
The first step I think is determining if they can be salvaged or not. The next would be buying any replacement caps and other parts I'll need to fix them up. The last is deciding if I'm brave enough to try it myself, or if I should just try to take them in to have the work done. Any pointers would be greatly appreciated!
Very Nice these are 1962 model W70’s. On your model everything comes out the back. They will definitely need to be recapped. It should have the sand damping incorporated into the case sides. If it is gone refill the sides with clean aquarium sand. I have had very good results using the non polarized electrolytic Mundorf E-Cap plains on my Wharfedale’s.they are cheap of very good quality. They have nicely preserved the Wharfedale sound on my speakers. I would consider modernizing the speaker terminals. But it certainly will work fine with what it has. The different shafts on the pot’s is an illustration of he over the counter parts Wharfedale used at this time. I even have price tags on some if the inductors in my W35’s crossovers. You have a real potential there.
important note I always caution it does not take much power to drive these speakers 35-40 Watts is about right. .
Hi Samaero. Congratulations. First, let me say how jealous I am! Whatever condition they are in, personally I would try to forget what you paid and concentrate on the beauty to come from them. If you made a mistake regrets won't fix it, it's done.
I am by no means the most qualified to help you, being just a beginner with old Wharfedales, but I can tell you if you have an interest you will have lots of fun (and head-scratching) getting the best from them. Before you start, take lots of photos of the overall layout inside the cab, the wiring, the components, so when things get complicated you can refer back and see how things were. Before you do that, label (use some non-permanent method you can remove later, don't write on anything!) each speaker A and B and make sure it's visible in each photo, (I know that sounds daft but my two are wired differently in each cabinet!). Have you any basic level skills in soldering and problem-solving?
I'm not familiar with that enclosure, can you reveal the driver fronts without removing them? You need to get a look at them and assess any visual damage. Then perhaps a good place to start is to disconnect each driver in turn and connect it to a low-level sound source to hear if it is working or not. You won't do any damage as long as there is low power.
Please come back and post more pics, the ones you took of the inside are too close-up to get a real picture of what's going on. This is going to be interesting.
That is a good suggestion. In this way you can ascertain how well each speaker is performing individually. If you find a speaker that is buzzing, look for anything that might be lose or unglued. You can also touch the cone lightly with your fingers to see if this changes the buzzing. If you have a speaker that is buzzing, unhook it from the audio source and gently move the cone up and down by applying pressure with your fingers - listen while you do this for any rubbing noises. If you have rubbing, don't assume the speaker is bad. Sometimes the magnet will shift position and cause this. You can loosen the bolts and reposition the magnet so it is aligned correctly to prevent the rub. If this procedure fails then you may have a burnt voice coil. In the case of a bad voice coil, there are usually plenty of W70 replacement parts available on e-pay. Note that your crossovers are identical, but it looks like someone has replaced one of the potentiometers. This is not a problem as long as it was replaced with an equivalent part.
Parts for these W70’s show up frequently for sale. Right now there is a Tweeter, a pair of Super 8 midranges, and a pair of the a Red Alinco 12” woofers from your model W70 available. I would set a watch for the crossover for your W70. I have a parts stash for all of my Wharfedale’s. Right now I am watching for a reasonably priced shippable pair of W60E’s.It is going to be interesting if a W70E, or a W90D comes up close enough to pickup.
Transmaster, ziggydave, infullview - thank you all for your input! I really do appreciate it.
This is a wonderful starting point. Re: the Mundorf E-Caps - would I just be matching the size of the caps that are currently in there? And yeah I'm not a fan of the screw terminals - looks like these may be a good replacement?
And re: the power - I've been driving them from a 100W (50p/c) Dayton Audio HTA100BT, and was under the impression that if I'm not cranking them (I actually listen pretty quiet - the volume knob is barely turned) I wouldn't be hurting anything. Is that correct, or was my understanding wrong?
Thank you! Oh I'm not regretting anything, just daunted, that's all! All excellent advice. I've never soldered a thing before, but I've got a soldering iron and now's as good a time as any to learn. The front baffles do not come off, so I can't see a way to inspect the drivers without removing them. I'll open them up again this weekend and get some better pics of the whole assembly for each speaker.
Thank you! This all makes sense in theory - I'll revisit once I'm a little further along.
Watch set for a W70 crossover on EB! If I'm replacing the crossovers with vintage Wharfedale crossovers, I'm still going to need to replace the capacitors, right? Is the goal of replacing the crossovers to standardize the tone pots?
Re: the Mundorf E-Caps - would I just be matching the size of the caps that are currently in there? Yes, providing they are original
And re: the power - I've been driving them from a 100W (50p/c) Dayton Audio HTA100BT, and was under the impression that if I'm not cranking them (I actually listen pretty quiet - the volume knob is barely turned) I wouldn't be hurting anything. Is that correct, or was my understanding wrong? No, that's fine, just don't forget and always check the gain is down before switching on. And tell anyone else who is likely to use them! I do not know that amplifier, is it vintage too? These would benefit greatly from an amp of the golden era, valve or not.
I'm still going to need to replace the capacitors, right? It makes no sense not to, considering the relatively small outlay and assuming they haven't already been done.
Is the goal of replacing the crossovers to standardize the tone pots? I'm not sure anyone said to do that? If they are working and the same spec it's not necessary.
Opening them up will give you a chance to check if the top and mid drivers are original (and take those pics for us! Take some close ups of the fronts too, I'm curious to see the detail) and if they are not, maybe replace those if you don't like the sound. Depends on your point of view.
They are gorgeous though (to me anyway) and money would be well spent on re-finishing those cabinets. Please be careful if you are considering taking on that role yourself, high-end cabinet refinishing is a very skilled job and you can easily make a hash of it. If they just need refreshing that's different and not too onerous. Happy to talk you through that if needed.
