Ishmael
Following up on Gang's question of where the noise is coming from one or more of individual speakers.
On the more noisy speaker, the woofer and mid-range are the source of the noise, the tweeter is quiet. On the less noisy speaker, all three of the speakers make about the same amount of noise which is considerably less than the noisy speaker.
The noisy speaker is the speaker that continues to play even when the attenuators are turned all the way down to the stop point on "minimum", which Toups notes should not happen. While the quieter speaker is the one that turns off the music when the attenuators are turned all the way down.
Final observation in both speakers when the attenuators are turned down to "minimum" the noise is less in the noise speaker and almost gone in the quiet speaker, and when the attenuators are turned all the up to "maximum" the noise is loudest in both the noise and quiter speakers.
It will be interesting to see if cleaning the attenuators tomorrow with Deoxit changes the noise in either speaker.
