To the gent with the XR-5's, we lost quite a few drivers that are customers complained about. But we had a 6200 trade in and a 754 amp we couldn't seem to sell. We would replace the mids and if they owned a receiver we would replace it with a 6200, if they owned a power amp would replace it with a 754. We would give them a month. out of maybe a dozen customers with issues we only had one more failure. That was a tweeter issue. It was actually resistor in the crossover network that failed. Some of the customers bit the bullet and bought Mac power amps. One talked us out of the 6200. One bought a 4300 or 4280. The remainder just learned to back off the volume a bit, one customer traded up to XR-7's another to XR-19. Others were never heard from again after returning the amps we loaned them. I assume they bought other speakers. Most folks don't realize the true handling power of a XR5 midrange. I believe there is posting here of a Mcintosh White paper with the true rating. Its an rms rating, and you can add 6 db for short peaks. I want to say 30 watts maybe, which is much lower than the mid and woofer, so if you allow your amp to clip they can fail pretty fast. Are You sure your crossover caps haven't change value allowing lower than specified frequencies to reach the driver.?
My curiosity got the better of me so I went looking. What I found was the power handling curves on an XR-16 which uses the same midrange driver, and the curves indicate out 30 to 35 watts rms for the driver. Maybe 100watt very short random peaks. Complaints about XR-7, ML 2 and 4's etc is one of many reasons Roger developed line arrays. Lower distortion as much power handling as the woofers ad better controlled dispersion with better clarity. I'd be looking for some XR 18's if I were you. If you want more there are XRT 28's.
Tweeter failures also spurred the development of power guard. I think large tube amps should have power guard also.
