c.coyle
Fighting the Dunning-Kruger effect.
It is Elna as I misspelled the option and I could not edit that out...oh well!
Just funnin' ya. That was too good to resist. Good capacitors are anatomically sound.
I've been doing the same as you. Do you have any thoughts on the importance of solid copper leads? Most of the non-audio types use steel leads with a thin copper plating rather than the solid copper used by the current and past "audio" caps. I know the "audio" part is a bit of a wank for most uses (decoupling/filtering), but I've wondered if the copper leads might have a non-marketing benefit. Interestingly a subset of the solid polymer types use them too, but not all (eg. SEPF and SEPC are solid copper, SEP is steel - not documented so I had to find out by buying a few). Interested in your thoughts.
I don't know in audio circuits, but all the UCh in my motherboards are bulged or destroyed.I like them all but have had very good measurements from United Chemicon .
I had the same experience as you, Elna (Silmic II) do come good eventually but they make things sound muffled and sluggish for ages. I'm not sure which "parameter" causes this, Conrad might. I found Nichicon/Panasonic (and UCC too) settled into their final sound much faster. I stopped using Elna since I felt there was no benefit over anything else for the wait.I like Nichicon and Panasonic, (voted Nichicon). I tried Elna and didn't like them, maybe I didn't wait long enough for them to 'burn-in' but I'm definitely not waiting 50 or 500 hours for any capacitor.![]()
Probably varies depending on circuit and the condition of the old parts.Very interesting zaibatsu, l normally use Nichicon KZ's (first choice) or FG's if l choose to use audio caps and have had great results with these, l have only used Elna Silmic 2's in one recap and that was in an Akai AM-2650 and it sounded terrific afterwards, sounded very clear straight up.
For what it's worth I recapped two of the same amp with all KZ and all Silmic II respectively (as much as possible anyway), both had all original parts beforehand (and the old parts measured fairly consistently between the two amps). Even then it's just my subjective experience.
I've replaced caps on my motherboard and my dad just brought one back to life with cap replacement. Switching supply filter duty is tough, plus we tend to keep computers on for huge numbers of hours. Some run warm, so now those surprisingly short life numbers in the data sheets start to be real world numbers. Supposedly the capacitor plague ended years ago, but I still see caps bulging, leaking and going bad. Fortunately, not often in audio gear. I didn't note the MB capacitor brands.I don't know in audio circuits, but all the UCh in my motherboards are bulged or destroyed.
