What is relative efficiency:
K402 is collapsing by half in the horizontal, from 100° to 50°.
The horn is 100 to 75 degrees...but what you're failing to acknowledge is just how smooth the beamwidth is. It's not swinging 25 degrees every octave like many of the horns you've referred to in this thread.
If you want a wider beamwidth above 7.5kHz, then pick a different compression driver...
I'm saying I care less about the vertical than the horizontal. I want the vertical narrow enough to mitigate floor and ceiling bounce and stable within the listening window.
Early reflections are but one behavior that affects perceived performance. There is a lot more to the polar response than just focusing a beam to avoid early reflections.
On that note, the beamwidth doesn't exactly tell the full story either. It's just an arbitrarily defined -6dB point. The shape of the polars can allow for a totally different power response with the same beamwidth.
So when you gonna get your hands on a Jub to measure one for yourself? :P
I don't want to avoid them, rather USE them, which implies controlling them. :yes:
Let's SEE 'em...! :tongue:
