What taps on your 501's???
two dot
Well-Known Member
Ok guys, what taps are you running your speakers off of?
There are enough "501" owners here we should get some good answers.
I am especially interested in LOW EFFICIENCY speakers like my LS360's
Thanks in advance.
Stephen.......I have my PMC EB1i speakers connected to the 4 ohm terminals on my 501's. I have seen the impedance and phase curve graphs for my speakers, and they present a very smooth 4 ohm load across most of the audio spectrum. The amps seem happy. I have hammered them on more than one occasion for extended lengths of time (just this afternoon with Edgar Winter - "White Man's Blues"), without any Power Guard lights, or abnormal temperature rise.
MCD500 direct to the MC501's, out to the Monitor Audio PL100's, with a little Sonos thrown in, on the 4ohm taps.
KMC,
Those are some great looking bass traps (I assume that's what they are). Where did you get them?
Alberto
Thanks in advance.
My Sonus Faber Guarneri Homage like to drink from the 4Ohm.
Alberto
I have used the 8 ohm taps on my XLS360s, XRT30s and B&W Signature Diamond speakers. I find there is a little more detail on the 8 ohm taps. Keep in mind, at the volumes I usually listen at, my MC501s are rarely putting out over 5 watts.
I use the 4 ohm on my MC500 to the LS360's.
I've tried the 8 ohm, and I get more volume with them connected to that, but it definately makes the amp work harder.
A couple times during some extended listening sessions at high volume the amp went into thermal shutdown while connected at 8 ohms...:tears:
I'd recommend 4, that's what those speakers are rated at...
Is anyone using two taps simultaneously, like 4 ohm taps for the woofers, and 8 ohm taps for mids and tweets?
4 ohms on my Final 86 dB.
I tried 2 ohms and 8 ohms on my 275 : it was not as good as the 4 output so I did not try the others on the 501...
Is this legal ?
This is perfectly fine to do with the solid state amps but do not try this with the tube amps.
When I had my XRT30 speakers I was getting too much bass in my room so I put the bass cabinets on the 4 ohm taps and the mid/tweeter columns on the 8 ohm taps. This gave me a 3db bass reduction which sounded good in my room. I later ended up using my MC162 amp on the bass cabinets in a bi-amp setup.
Thanks in advance.
I am using 4 ohms on SF GMs but you should try both and see which sounds better to you.
I run the 4 ohm taps for my LS360s. I listened at length with the 8 ohm taps and the sound was a little "brighter" and I initially liked it but after further listening it didn't seem as smooth and balanced with my room/system so I switched back. It sounds so good where it is supposed to be that I really haven't worried about it since then. Hope that helps...
I have been talking with lyle1 in the PMC Owner Group. He is driving a new pair of PMC EB1i speakers with MC501's, and is using the 4 ohm taps for the woofers, and the 8 ohm taps for the mids and tweets. The PMC EB1i is rated as a 4 ohm speaker. He tells me he hears greater detail using the 8 ohm taps for the mids and tweets. Since he is in Alberta, Canada, and I am in north Florida there's no way for me to drop by for an audition, so I will have to take his word for the greater detail. I would be concerned about how the 4 ohm load on an 8 ohm tap might effect the mid range and tweeter frequency response, as well as the balance of those drivers outputs with the woofers.
The 8 ohm tap will be 3db louder than the 4 ohm tap. The bass reduction could be why he is hearing greater detail.
