What year is this Zenith ???
babgrip
Member
Can any one help me id this console. Year, Amp and Tuner section.Turntable. Is it worth parting out thanks. Model # mm2603 chassis 3l02 ?? 7l01-3l02 7695 output tubes . all tubes are Zenith made in U.S.A
It looks like a single ended amp with a hot chassis. I do not see a power transformer. Is it worth parting out, no not in my opinion
Service info is in Sams folder 727-10 - 1964. Yes those are series string tubes - no power transformer. "Danger Will Robinson!"
hot chassis amps are perfectly safe as long as you run them in the cabinet with the knobs in place, and never for any reason attempt to plug external devices into them. Just don't ever stick your fingers in there, or you'll be singing like Whitney Houston, "You Light Up My Life".
looks like one of zeniths lesser offerings. could always do what i did and use the console in the carport or garage.
Agree with the hot chassis. Date between 1962 when Multiplex came out and 65 when most of the Manufacturers started over to SS.
V-M Turntable.
Larry
Its a 1965. Zenith Model numbers in that period were different every year.
MK 1963
ML 1964
MM 1965
MN 1966
In 1967 they changed to a X as the beginning. I'm not sure what happened after that since the later units are nice but not so much of interest to me.
Debby Boone maybe?
Kind of surprising to see that little amp in the big console. Must have some real high efficiency speakers in it. How does it sound?
