ConradH
Lunatic Member
IMO, most concerns about capacitor types for 50/60 Hz conventional audio power supplies aren't worth wasting a brain cell on. The only factor that affects performance is the capacitance value. Dissipation factor (or ESR) barely gets involved. Let's take a 6800 uF cap with no losses, a perfect cap. It would have an impedance of 195 milliohms at 120 Hz. Now lets say the dissipation factor is 0.3, which is more than three times greater than the datasheet says it should be. Impedance is now 204 milliohms and the 120 Hz ESR is 58 milliohms. Not worth worrying about.
Only slightly worth a brain cell is if they sent you a capacitor that was 10% low, which IME is quite likely. If it had no losses, the impedance would be 216 milliohms. Still of no concern, but it's a bigger factor than that made by low ESR caps designed for switching supplies. Instead, worry about lifetime, solvent resistance and if the lead spacing matches the PCB. Stressing the seal by spreading the leads is worth worrying about. If you need a low leakage cap for low level sections, that's also worth worrying about. FWIW, I've never measured an "Audio" capacitor that was one bit different than standard commercial grade parts.
I haven't worked on anything, much less bought new caps, in a few years. I see FG is now "Fine Gold" and recommended for audio. Last I knew it was just a good commercial part. The datasheet looks the same as before. Is it something different or the same old part with a fancier shrink sleeve?
