This.
I wish I had the shekels to have amps like that in my system. Unfortunately I choose teaching as my profession, so I have to bottom feed when selecting audio components.
This.
I wouldn't say bottom from looking at your signature. :thmbsp:
That's kind of you to say, but I do sometimes think that my amps are the thing that's holding my system back....of course that's probably just the audiophile neurosis talking. :scratch2:
Where do you guys see the High Current in this one?Looks plain integrated to me.
Um, that big copper colored thing in the lower right.
Although not guaranteed, a toroidal transformer is usually a good indicator of a highly capable power supply - i.e. high current.
What do you feel its missing, soundwise?
Overall, I would say that my system sounds sterile, it lacks the organic sound that should be present on good recordings. I'd love to hear what a low-powered SET would sound like in my system, but my speakers wouldn't play nice with that type of amp.
I would try a different amps. Although I like Emotiva stuff, they have been described as sterile. I would try to get an Aragon amp.
Been like that ever since the FTC was de-regulated - see here.What I find most ridiculous are companies that produce literature that list current specs that may be possible under some very weird test conditions for a few milliseconds, but is impossible to achieve under any real world conditions.
H/K is probably the worst offender of that, but even my B&K amp listed +/-75 amps and there is no way possible for that to ever happen. Even if it could somehow, it won't ever in real world use so it's a stupid spec. It's marketing though, and apparently it helps sell products because the spec looks impressive.
I'm with Steve on this. Only spec you need to see is the ohms rating. If its 4 ohms rated it will survive dips even under 3 ohms. If its 2 ohms or 1 ohm rated, then you can weld your fence with it.
