Guys I think we can agree we all listen at much different levels. No big deal, just different.
If that was the only disagreement here I would never had posted.
I guess we'd have to define 'average listening levels' first! I
Yes I'm aware of that. And whatever the SPL is at 13', I still do not average 1 watt per channel with most music. Sometimes I'll have to set the meter sensitivity at the -10dB setting (whereby full meter deflection is 5 watts) just to get a reading.
Mine is much closer to 85-95 like GChief posted above. It really depends on the music, I think. Some stuff just sounds lame at low levels, and some has bass that one needs to almost feel, while other types would give me a headache at higher levels but is fine lower.Indeed!. What SPL can the average listener tolerate for an indefinite duration? I submit it is no higher than 70- 80 dB but that is just a guess.
62caddy you listen at levels much lower than some of us. !
Even less is needed with speakers of high sensitivity (95 dB /+) where average listening levels might hover around several 1/100ths of a watt with 20 dB peaks requiring a "massive" 2 - 5 watts to resolve cleanly.
Yep, forgot about that. It doesn't allow the clipping by reducing the power output so it can't. You lose the dynamic range of the music either way, sounds better without clipping though.
What is the sensitivity of the speakers you use with the 6wpc amp at 95-100db listening levels and how far are you from the speakers? Just curious.Mine are 85-95 at my listening position. Some songs get 100ish. All measured on a calibrated meter I use at work.
How often do you suppose the power lights would flicker on the 2 to 6 watt amps discussed here if they had the power guard feature?Most of us who have sold or owned PG equipped McIntosh amps for the last 40 + years have come to understand that seeing the red lights flash occasionally is OK, the more you see them flash, the more you ask the amp to exceed 1% distortion the more you guessed it, you need a bigger amp.
Well, seeing the numbers you quote with the 18 x 16 room, the math says you have absolutely zero amplifier headroom available (actually negative headroom) with your amp and speakers at an spl of 92db at your 10-foot listening position. The picture is even worse if by "low 90s" measured listening levels you meant anything above 92db.93dB. I am right around 6.5’ away. I also ran this amp in a 18’ x 16’ room with the system on the long wall, the sweet spot was about 10’ away and with KG4’s the amp would do low 90’s (measured) comfortably.
Is your source material very compressed or otherwise lacking dynamically? Could your ears be adapted to clipping distortion?
So, 6 watts with 3dB of headroom, and 12 watts with 6. Maybe get anther 2-3dB from room reinforcement. Dynamic material would still be clipping, but probably not to the point of serious degradation. If I remember correctly, the amp is rated at 6-8 watts (assumedly using the RMS method). A good amp could make near twice that at peak power...so I think the math works to illustrate what GChief's ears tell him...the amp can satisfy his needs.
