Yeah, I don't understand why some can't grasp this.
Maybe it is because they have put a lower power amp in place of a higher power amp and heard no difference or even possibly an improvement.
I know I have.
And my post #170.
I love reading post trying to explain away what many of use every day, it entertaining
Yes, you and others do it every day, but until it's done with your amps in my living space, with my speakers, with my source material, and at levels that I want, it remains a 'it works for me' thing and not a universal. For example, I do not like KG4's. Or the 3.5's I had, or the 5.2's I've heard. I was less than impressed with the fully updated Fortes I recently heard. Each sounded like two speakers - one with highs and mids, and another with bass; it was very disjointed, if that makes sense.And my post #170.
I love reading post trying to explain away what many of use do every day, it entertaining
Here's same spreadsheet from my earlier post, with 89 dB speakers, which is more typical of what the avg Joe has in his casa. Simply listening at avg SPL of 86 dB using 4 watts avg, your amp will need to supply around 40 watts a side to be able to avoid clipping on moderately dynamic material. And if you want concert level without clipping you will need many many watts, and a very high power handling set of speakers to go with it. As was stated earlier, clipping of the waveform is quite common in our listening. I suppose the loudness wars helps with this, but that built in compression sounds even worse than occasional clipping imo.
However, I do have a newly updated ST-70 to play with. I'll connect it in place of my normal 200 watt amp and see how it goes. My primary speakers are ADS M12's that are only 87dB efficient, so I'm curious if the 35 watt amp can produce the same levels with the material I generally play (with quite a bit of bass). I do know that the ST-70 sounds great on ADS L-520's at 92dB efficiency and Dahlquist DQM-9's at 95dB. I've wanted to replace the banana plugs on the M12's, so doing this will give me a reason to swap in the ST-70 for a bit... hopefully, it'll cool down a lot before I do it this evening!![]()
.Have you ever measured the spl in your room at different distances?
I have and in my living room the rate that it falls off is very slow, not anything like the charts I see that are probably more about large venues.
I listen at more like 8' and with 89 dB speakers I do fine with @ 10 watts; just as the chart seems to indicate for my listening levels.
When I had 85 dB speakers I found @ 20 watts did the job.
I've got 520's, 780/2's, and M12's at home and L300c's at work. I think the efficiencies are in that order. I'll give them all a listen-to. The 300's are at work and not worth taking home for this, as I commute via train. Which amp do you use on the 710's, the Dynaco?sounding great with my ADS710’s also. Little more space tweaking and all will be good in the world. I understand about the heat, that’s the main reason I also have a SS amp![]()
The arguments have not been that everyone needs to have and enjoy the same systems and loudness levels that we like.
We just don't agree that what we have and how we listen will improve by having more power.
We have had (or do have) more powerful amps and choose to use lower power amps because we like them better in our systems.
I think you're grossly overestimating average listing level at 4 watts. With a pair of 90 dB speakers at a distance of 13', (which, don't forget is 93 dB for a pair with 1 watt input each), I can't even get a meter reading on an MC2505 for average levels which is nowhere near 4 watts; in fact one watt for average listening levels would be high. For most listeners with speakers of moderate sensitivity (which I would classify as 88 dB - 91 dB) average listening levels require only fractions of a watt meaning that even modestly powered amplifiers would have no difficulty providing ample headroom.
Even less is needed with speakers of high sensitivity (95 dB /+) where average listening levels might hover as little as several 1/100ths of a watt with 20 dB peaks requiring a "massive" 2 - 5 watts to resolve cleanly.
From what others post, I should be fine with any of my speakers on that 35 watt Dynaco, but I know that I've seen clip limiter lights flash on a previous amp with my main speakers. I believe that amp is rated at 420 or 440 watts at 4 ohms.
Everything in the spreadsheet is by the book.
FYI, If you have 90 dB speakers they are rated there at 3 ft distance, not 13 ft.
I guess we'd have to define 'average listening levels' first! I've mentioned it in the past, but at the last SoCal get-together, the 500wpc Mac amp was driving a pair of ADS L1590's. I sat there and watched those meters in the 50 watt mark for much longer than just peaks. The peaks were way over to the right in triple-digit territory. In fact, here's a pic of them at 50 watts, and if I'd been trying to get a pic of peak reading, it would have been pretty difficult on my old iPhone (it's a crappy pic I know). I won't say 50 watts was the average for the entire time we listened to it, but it was definitely not peaks.I think you're grossly overestimating average listing level at 4 watts. With a pair of 90 dB speakers at a distance of 13', (which, don't forget is 93 dB for a pair with 1 watt input each), I can't even get a meter reading on an MC2505 for average levels which is nowhere near 4 watts; in fact one watt for average listening levels would be high. For most listeners with speakers of moderate sensitivity (which I would classify as 88 dB - 91 dB) average listening levels require only fractions of a watt meaning that even modestly powered amplifiers would have no difficulty providing ample headroom.
Yeah, it was my amp, my speakers, and in my bedroom.Did you hear it?
