TEST RESULTS: ALEENE'S TACKY GLUE
I'll cut to the chase. its cheap and easy to find (Wal-Mart for starters) so I had to try it. All comparisons are being made to Titebond-II. (TBII)
Pour: much harder, requires a much harder squeeze on the bottle, almost tiring.
Spread: Extreme effort using thin plastic card. Requires tremendous down force and much consternation compared to the easy spreading of TBII.
Dry Time: Faster than TBII... perhaps 5-6 hours with no fan.
Adhesion & Peel: Extremely EASY to start, dried Aleene's is very much rubber and elastic. Very much Stretch Armstrong toy-like. I like this aspect for the fact that there is literally ZERO edge shards, the mask will stay 100% intact every time. Requires alot of stretching to remove, but adhesion is not the issue, stretchability is.
Cleaning Ability: I am suspect that Aleene's may not clean as well as TBII, although I cannot say for sure. I feel, at worst, Aleene's is VERY close, but may not be "snagging" all the fine particulates. I am not confident that it gets down as deep into the grooves as TBII. Test cleanings left some ticks on a very nice ffrr piano LP, while background "floor" was immaculately clean.
DECISION & NEXT IDEA: I want to mix a 70/30 formula of Aleene's and Titebond II. I believe this will give a "perfect" Glue for cleaning LP's, the solid stregnth of TBII and the elasticity of Aleene's, with, hopefully, the elimination of any chance of edge remnants, while retaining the ease of application and flow of TBII.
