Thanks Gusten, I tend to agree with you, although in the case I mentioned the problem was essentially caused by very warped records (I have quite a few of those thanks to storage in a hot environment in past years), and the low frequency woofer cone movement was as a direct result of the record warp and not any cartridge/ tonearm incompatibilty.
In any case the use of a good sub sonic filter has other advantages such as 'cleaner' playback due to reduced intermodulation effects and greater available amplifier power as the amp is no longer required to reproduce the sub bass signal rubbish. Regards, Felix aka catman.
