Nice distortion exactly but speed fluctuations. That .27 is very high (not good) and .01 is very respectably low (very good). Which turntables are these?
Thanks, think I'm going to buy a new Dual. Didn't know they were still in business0.10% or less was the old NAB standard. IMHO any turntable that can't manage that isn't fit for use.
Thanks!!!!!!!0.27% is very high
Think I am going to buy a new Dual. Didn't know they were still in business.I'm looking at two turn tabled to buy. One has a wow and flutter value of 0.27% and the other has a 0.01% Am I correct that the more wow flutter the more distortion?
https://hifiheaven.net/shop/Dual-CS...artridge-Open-Box?search=Dual&category_id=137
Wow & Flutter: < ±0,1 % (DIN WTD) - this is a respectable number.Thanks, think I'm going to buy a new Dual. Didn't know they were still in business
This is all written in Japaneese, can you please explain in English???????![]()
Smaller number is better, but you cannot compare them without knowing what method has been used to obtain it, and there were many (see the link in my signature).
So, it is 0.1%, not 0.01%, which is unachievable on a real-world turntable. I suppose, it is either JIS or NAB, but there is no indication which one. Also, no indication whether it is weighted or not. Unweighted can be easily three to five times higher than weighted, but since manufacturers like to advertise low numbers, I suppose it is weighted.
The other one, considering "+/-" and comma in decimal, is either DIN or IEC. Should be quasi peak.
If the fluctuations are perfectly sinusoidal, then JIS value would be 0.7 of DIN value. In reality, JIS value can be anywhere between 0.3 and 0.8 of DIN value.
As a rough estimate I usually consider DIN value to be twice higher than JIS, like in your case 0.1% JIS WRMS is about the same as ±0.2% DIN Quasi Peak, so these two turntables are quite close in terms of W&F.
For hi-fi turntables and cassette decks, DIN requires W&F no higher than ±0.2% weighted quasi peak, so ±0.27% does not look very exciting to me, unless it is an unweighted value.
Wow & Flutter: < ±0,1 % (DIN WTD) - this is a respectable number. Of course, digital will give you
This is the best I can do to explain it in written English: wow & flutter explained.This is all written in Japaneese, can you please explain in English???????
If they really had 0.27 RMS w&f, it would sound so bad that anyone buying one would feel ripped off, so I somehow suspect it is peak to peak values.
They are not RMS.Those project turntables likely are fine, it's hard to understand exactly what those specs mean. If they really had 0.27 RMS w&f, it would sound so bad that anyone buying one would feel ripped off, so I somehow suspect it is peak to peak values.
Actually, those 0.27 % and 0.25 % values don't seem so unlikely. Because the Automat A1 basically is a variant of the discontinued Dual CS415-2 and made for Pro-Ject formerly by Fehrenbacher, now by Abundantia (which took over, after Fehrenbacher went insolvent this year) - and most probably it still sports that lousy drive variant with the fixed spindle, that doesn't turn with the platter, so that the record may rub against that, hence causing quite inacceptable wow & flutter. In one word: Avoid!
Greetings from Munich!
Manfred / lini
Unfortunately the Fluance turntables also have a fixed spindle and I hate it. Why would anybody think that is a good thing?and most probably it still sports that lousy drive variant with the fixed spindle, that doesn't turn with the platter, so that the record may rub against that, hence causing quite inacceptable wow & flutter. In one word: Avoid!
Manfred / lini
