MBentefor
Dear AK-community!
First let me say big hello to all of you and introduce myself:
My name is Gene, I am from Ukraine. Have always loved music - just music as it is. More exactly speaking - a music material. So I never really cared about the sound itself. Is this Dougan's track in mp3-64? Great, lovely listening!
Several years ago because of few reasons I started collecting some vinyls (of a wide genre selection), as an addition to some soviet and chinese turntables, I've bought myself Dual 627q (with a new AT95E). It was all great. However there were always two problems: my amplifier had several issues (will list them later) and my speakers .... let me say lacked something. (amp - Dynasty 9100, speakers - Siemens, some strange model with no info same as the amp)
So now, when I got a little bit closer to all these audio devices, when I understood, that the way some speakers sound is totally not acceptable for me (and some headphones too: for example Xiaomi or Behringers or Beats all of which modify response curve to add more basses - more than was monitored when recording at same volume), when I understood I want "truh" sound; Clear; Flat; Like the one I listen to in life: concert halls, theaters and so on - now I decided to build a new system for myself.
The system requires CD player, cassette deck, turntable, amplifier, speakers. Maybe also an equalizer.
Cassette deck already bought - Denon DRM 800 in perfect state.
I am thinking about getting each item from another manufacturer - so that later i can understand which factory is more reliable (although I understand, that opinion made up just from one-item-from-each-set can not be really correct).
The next step for me is to get an amplifier.
As I am not any kind of audiophile (rather musicphile), I will never spend hundreds of dollars for my components. For example, Dual+Dynasty+Speakers+Cartridge costed me 450 dollars. And that is fine for a full system. Unfortunately, half of that system appeared to be a garbage.
Here is why:
speakers
Now finally - let's get to the point.
I've made some searching on local "ebay" and found 5 items that look like normal devices. I was able to sort away more than 150 amps, but still I have too few (actually none) XP points to make decision myself.
I will do this the following way: Name - Link to HFE - Price in USD.
If needed - I can also send pictures of the items.
Let's go:
Harman Kardon PM655VXi
http://www.hifiengine.com/manual_library/harman-kardon/pm655vxi.shtml
$196
Marantz PM-52
http://www.hifiengine.com/manual_library/marantz/pm-52.shtml
$140
Marantz 1030
http://www.hifiengine.com/manual_library/marantz/1030.shtml
$144
Braun Regie 450
http://www.hifiengine.com/manual_library/braun/regie-450.shtml
$118
Onkyo TX-DS575
http://www.hifiengine.com/manual_library/onkyo/tx-ds575.shtml
$104
Answer "none" is also acceptable.
Thank you all who answers me!
Oh, one more thing - I am not that good in electronics and free time, so would be nice for device to be reliable - so after buying I will have no need to change something, solder, or buy another amp.
With best wishes from a picturesque Lviv,
Gene
Here is why:
speakers
- lack basses and
- there is a slight difference in the middle-freqs, so sometimes I hear person singing in the middle, but then suddenly he swims to the right. Then to the left. Then back in the middle. What a nice swimmer!
- no MONO button,
- not a single option to modify in phono (change capacitance, load, cut-off (or whatever that riaa point is called), mm/mc or anything else; actually don't need mc),
- once per 2 minutes - high frequency jump, which is clearly visible on Frequency Analyzer and on recorded (ripped) track,
- SNR on phono inputs is -58 dB, while I need -70 dB - this is the point when you can't hear humming anymore;
- high freq humming which is really hearable in some specific points in the room;
- and... that's it probably.
- correct (~+-0.5 dB) RIAA phono,
- low (-70 dB at least) SNR in phono and others too - NO hearable humming/whistling/buzzing from speakers or headphones, no matter how close you are, the only acceptable is veryveryverysilent pink noise, as made by amplification of non-ideal-zero signal,
- MONO button,
- flat frequency response on normal volume level (have no idea what is normal - probably the one I can listen to in the midday not being afraid to disturb neighbors),
- cheaper than 1 trillion USD (actually cheaper than 200 USD).
Let's go:
$196
Marantz PM-52
$140
Marantz 1030
$144
Braun Regie 450
$118
Onkyo TX-DS575
$104
Gene
