klamsoss
Be willing to fail and try again.
I'll do a full write up this summer when my resto-mods are complete, but I need some help to get there.
A trusted tech in TX made my unit functional. The work was just fine, and I have really enjoyed the few hundred hours of listening, so far. So much so that I'm ready to take it to the next level.
Initially, I'm upgrading caps and trying to get the best matched quad from the dozen or so 7868s I have accumulated.
I've ordered k40y9 and k42y2 caps for the preamp, based on comments from many on AK, especially audiodon (R.I.P.).
I have installed 100R grid stability resistors and 10R cathode current sensing resistors. I followed Bruce and Dave's discussion of the cathod and stability resistor mods in this thread:
https://audiokarma.org/forums/index.php?threads/x-100-b-w-7868s.441082/#post-5656060
Bruce's "busses" have been replaced with "trunk lines" in my implementation. I ran a wire from the appropriate node and the resistors are floating connections (heat shrink covered) off of that. Sort of similar to (but much more messy than) the arrangement depicted in Dave's thread here:
https://www.audiokarma.org/forums/index.php?threads/kx-100-fishers-intro-stratakit.673654/
My issue is that I haven't been able to find a thread that explains the details of how to suss out the most closely matching 7868s, from a collection. I understand how to measure the current for each tube over the resistor, but the actual sequence of turning the amp on and off to switch tubes out... I know I'm measuring quiescent current, so no signal, but do I let it run for 20 min to warm up? Fully cool off after each tune is switched? Do I reset bias every time I change a tube out? Is there a reason to keep Sylvanias with only other Sylvanias and RCA with RCA? If someone can give me a procedure for it, that would be a big help to me.
Eventually I want to do IBAM and/or Dave's EFB, but I'm not an expert with this stuff yet, so, starting with baby steps.
Photos 1 and 2 are the same pic, but one has my attempt to highlight my "trunk lines" and how I have them set up.
The blue sleeved trunk are the 10R cathode current sensing resistors. This trunk is connected to the nodes indicated by the schematic: pin 5 of V4, C4+ (100uF cathode cap), the cathode cap's parallel 560 ohm high watt resistor (I used a 10w wirewound), and R76, which is linked with the bias adjustment pot (these are traced in brown).
Similarly, the grid stability resistor trunk (yellow) links with the 2.5kR 10w (R72) and 40uF filter cap ( C2b) (red trace), and the 1kR (R73, orange trace).
The third pic is the relevant portion of the schematic, with my color scheme noted on it.
The last one is just a nice shot of my Fisher amp sitting next to my FM-100-B that I have restored with the help of the AK braintrust.
Thanks guys!
-Sam
Thanks guys!
-Sam
