Did some more work last night and today.
That tone board really needs every solder point reflowed AND solder added. I would say 70% of the joints hardly had any solder .
50% of the transistors where loose, the two 22uf caps also were loose . As I heated the solder points you could see the solder get sucked into the hole
and leave an opening, hence the need for more solder.
The driver board I only changed the trim pots.
I first removed the existing pots and measure the left side terminal to the wiper and made note of that reading.
I then aligned the new trim Pot as it would go in the board and connected my DMM to the left leg and the wiper( same as the original trimmer) and
dialed in the same reading as the original that was removed .
Both replaced
There are mostly carbon filter resistors and I was going to go with all metal film 1% but figured it might change the sound too much. So on this build I am not going to.
But on one of my other A-1's ( USA versions ) I might go for it.
On the pre amp board I decided to remove the MM/MC switch and have a looksey indie to see what might be going on with all of the switches. This one also would stick a little.
So I figured Id clean it up lube it with D5 and hope it worked out the kink.
Upon removing it the one solder bad broke off, this was even using my Hako 805 de soldering gun.
I'll address that after I take the switch apart.
Yep, just as I imagined, oxidation !!!!
The inside of the switch didn't look to bad. And i did want to attempt removing the lid so I just sprayed D5 in there and cleaned the spring
fingers on the switch shaft and worked it back and forth .
Well the switch was still sticking and I didn't want to chance it that it might stay stuck one way or another. So I happen to have some C&K switches that
have gold contacts. So in this spot where the MC signal goes through it I think its a good choice.
One issue I had tho was the switch carrier that is for th the ALP switches is narrower longitudinally . so they wouldn't fit right.
I had to trim the slots wider that the switch uses to slide into the carrier, and then also some on the front and back of that area.
I forgot to take pics as I was annoyed but I got it to slide on and fit.
Pic of old switch and new C&K switch . You can see the slots I am talking about on the old switch easier than the new one. But I had to make that front part of the body on the black switch as narrow and the
grey switch so that it would slide onto the carrier. It needed, I would say, about 1.5mm triming all together. A little from the front slot and back slot. And the same amount from the front and back bottom of that front section.
If you have to do it you'll see what I am talking about once you get in there. Not sure if Alps make the same switches anymore. I like the C&K switches as they have a more firm feel when depressing them.
Here is the repair on the PCB from the lifted through hole pad. I scratched the trace to expose the copper and flowed solder from the pin tot he trace.
Not wanting to damage the PCB any more I decided to take part the other switches on the board and spray D5 anthem and re instal the shaft with the finger springs and work them a bunch of times.
you need to bend back the carriers switch hold down fingers, there are 4 on each switch.
And the switch opened up, flip it over when you remove the shaft as the spring clips might or will fall out of the shaft.
Now spray DeOxit 5 into the switch where the contact blades are and reinstall the shaft flipping the board over again bottom of PCB facing up.
It takes finesse and patience to re insert the shaft with out bending the finger springs. So TAKE YOUR TIME.
Do this to all switches, the source selector switches are a little more involved as they have a toggle feature that connects
all three source switches together. You have to hold the connecting arm to one side so the shaft can be pulled out. Re-inserting will need the same procedure.
Spraying D5 into switch.
I guess if you wanted you could replace all the switches with C&K and get their carrier for them. Not sure if they have the proper
switch spacing though. I will investigate and report if its possible. then you could use all gold switches with will oxidize much more slowly or not at all.
there are only 4, 1 uf caps on this board, those have been replaced.
thats it for tonight.
Athanasios
