This part takes the most thinking of the whole restoration.
No matter how many pics you take you can still get easily confused. Next time I'll
take some notes of what I took apart first along with the wires that were desoldered.
But it wasn't too bad. A few harnesses looked similar but figuring it was helped by using the
silk screen labeling on the corresponding boards.
The first board from behind the faceplate to install is the last board I took out, which I forgot and why i need to take notes next time
And that was the pre amp board.
There are three plugs to reinstall from the volume board( mentioned below again) and also the RCA connections, the three colored encased 4 wire harness's , Blue, red and Grey. These come from the back panel .
There is the GND harness's with the 3 black wires, and a harness from the 'Lytic board.
Also there is +/- 35 volt wire harness and another harness with a red and white wire that
also is a +/- 35 volt line. one comes from the 'lytic board and the other goes to another board. I believe the
Tone board IIRC.
The volume board is next and has three plug in harness's that get connected to the Pre amp board, #1,#2 and #3 Also make sure you feed the #4 harness between the pre amp board and the chassis so it can get plugged into the volume board. And there are the orange and blue RCA's that connect here. These are the MC signals as the head amp is on this board.
Here is the location fro the #4 harness fed between the pre board and chassis
Last is the tone board. This has a harness that fell apart and in the above pic as you can see. These get soldered to the tone board . Also there are two colored wire harness's that get soldered to the bottom of the Pre amp board towards the bottom. One under the plug in harness , this gets the white wrapped wires
and one between the bottom two switches , this is the red wrapped wires .
Here is the amp with all boards put back in.
And another, face plat on but knobs still not installed. Also need to address the lights. I thought I had one that worked but now none do. I may need to check the voltage for those.
All adjustments were made after a 20 minute warm up and dialed in nicely.
Tomorrow i'll hook up some speakers and check how it sounds.
there are some other small issues i'll talk about later.
Athanasios
