Was this FR403 in the phono stage? Can't see that causing measured voltages if AUX selected.Decided to check the fusible resitors( 47ohm 70ma ) and one on the left channel measure in the kohms. So There is one issue.
Or FR503? or...
Or FR503? or...
I'd power up with DBT to check for shorts, don't look at DBT voltages. Power up normal if DBT ok then check voltages...Should I replace them and fire her up? They are 47 ohm 1/4 watt Metal film
Little too close to the +35V rails possibly pointing to TR415 or TR409 or TR411 c-e short or...The left channel still shows 32.xx VDC
Is your negative rail present ?The left channel still shows 32.xx VDC and adjusting VR 401 . Both fusible resistors measure ok.
R443, 330ohms, open?
EDIT:Scratch R433(typo) should only see low voltage.
C411 33P polystyrene would be a long shot.
One approach would be to track down the source/path of the high voltage, ie, starting at the TP (+32.xV) test at TR415base, expect +33.xV, if TR415b is lower then test R455, if that is also lower then got to be TR415c-e.
Thought problem was with the left channel. I'll continue to reference left channel
TP is high, base of TR415 is "0.65V" higer, next would be TR409 and TR411 emitters, hopefully one emitter is at the same voltage as the collector (=TR415 base), this would indicate a c-e short under load. Failing that leaves C411, this is a polystrene, unlikely to fail, in this case check voltage at TR409b
Feeling motivated, I grabbed my A1 from the corner, replaced the blown 1AT fuses (F202,3, wtf?). Variac'd it up, set voltages/bias etc and it's been playing happily. Must have a bad solder connection or damaged track or... to explain the previous bad behaviour...
TR409
b= 32.48
c= 33.19
e= 33.17
TR411
b= 33.20
c= 33.18
e= 33.17
