Sorry, the p2200 main caps are bolted in. They're also the leads. You'd use an appropriate resistor and leads and touch them to the indicated solder pads you showed. You can use a multimeter to check them for voltage first.Hey Martin, thanks for your help.
When you say ‘cap bolts’ can you add a bit more detail, or describe it another way.
(I’m sure that any experienced repairers reading this must think I’m...)
Without having one to hand is there another workaround?
A couple of 10W 8ohm resistors soldered in parallel for longer..?
basically yeah
