The "instantaneous" current will be about 50Volts/R, so using 1ohm will give 50A!!! using 1MEG will give you 50microA.
The instantaneous power dissipation will be 2500/R, so depending on what you have on hand, eg, a 1W 2.2K, but this
will be a bit slow (22mA), I'd be going with 200-1kohm, 5W. I simply hold the resistor body with some pliers and then hold
across cap solder joints, ok, a bit clumsy, so use clips/wire.
Is the amp working normal before you start the refurb?
