Yamaha A1 restoration 2021
My apologies to @avionic
Have just discovered that somehow.. I must have managed to select 'ignore content' in my settings!
Corrected this now and can see all his incredibly helpful and timely comments on this thread alone, what an own goal.
Anyway, thanks Avionic for all your help, hope you're keeping well and very glad I've actually discovered this error.
Thanks Avionic, but I’m in UK and can’t easily use bdent unfortunately I think...
Are either of my two ok in this location do you think?
Amp working and sounding very good... BUT
Idling Current has an adjustment issue.
Any advice for this issue?
TP1 - TP3
The left channel will only adjust between -0.3mV and -2.9mV.
-2.9mV is achieved by turning the Bourns (VR101) clockwise to it’s fullest limit.
DMM black lead on TP1, red lead on TP3.
TP2-TP4
The right channel’s range is between 0.00mV and -0.8mv.
The DC Offset is great at a 0mV to 10mV gentle fluctuation on both channels.
TP1 - TP3
TP2-TP4
Your looking for 7.2 to 7.6 mv
Check your emitter resistors R113 thru R116 .47Ω @ 5watt
Thanks Avionic, especially appreciate your help on this one.
Those Emittor Resistors are all brand new and pretty sure I tested them before putting them in..
On the Drive Board I replaced TR 525,6,7,8 with those TC resistors you recommended too.
TR137,8,9,140 were also replaced.
I went by this, attached below.
From where should I attach test leads for reading the idling current? The SM has so many errors...
Set your meter to volts
Clip your meter leads to each end of R114 and adjust VR101 for .0074 volts.
Then clip your meter to each end of R113 and adjust VR102 for .0074 volts.
Or set it the meter to mv
7.4 mv is target.
This is the second optional test points I was referring to yesterday.
Thanks.
For R114, is it definitely VR102 that gets adjusted?
Only asking as I’m thinking it’s the VR that’s on the other side of the board.
