Hifibythekg
For these purposes does the 2SA844 need to be desoldered from the board to obtain the Vbe?
Problem may be with TR607, measure Vbe of sample KSA1015's and compare with 2SA844 oem.
Measure dc voltage (mV) between TP1 and chassis/GND, repeat for other channel.
Always power off for resistance measurements“Have you checked R627 4.7ohms, measure incircuit.”
Set DMM to ohms, and measure resistance with mini grabbers with power on?
So... left channel is ok? Problem with right channel...With power on right channel measured -15.9mV but would not change when trimmer turned.
Left channel would adjust so I put it at 10.0mV.
Need measurement on the faulty right channel. 5.1ohms is okOn left amp board with power off, R627 measures 5.1ohms.
Left amp board.
0.068V - 0.724V
Right amp board.
0.046V - 0.716V
DC offset, so not a lot. TP1 is the transistor emitter, TP0 is the speaker line and chassis being ground. Measuring betweenwhat’s the difference between measuring between TP1 and TP0, and the chassis and TP1
Bit of confusion with my intrepretation of post #63I presume that even though the left amp board showed that the VR could affect the readings when connected Chassis-TP1, there is still a problem because the VR doesn’t affect readings when attached TP1-TP0?
.Left channel would adjust so I put it at 10.0mV.
Above voltages were for VR601 wiper, schematic shows typically +1.2V at this point, being 2xVbe to get over TR611 and TR613.Left amp board.
0.068V - 0.724V
Right amp board.
0.046V - 0.716V
