Voltage at baseMeasure the voltages around TR801 through TR804 and post results.
TR709, TR710, TR711, and TR712
I need all voltages please. E,B & CVoltage at base
TR801 -90mV
TR802 +2.5V
TR803 -100mV
TR804 +2.5V
Maybe, maybe not.I’m assuming TR803 and 804 are my issue here.
Diode test:I need all voltages please. E,B & C
Maybe, maybe not.
Is this a canadian ( 220v) model?
Black meter test lead connected to chassis ground. I use one of the neg. speaker binding posts for a good ground. Then probe the Emitters, bases and collectors with the red meter lead.TR803 ~50mV at the base, base to collector ~10V, base to emitter 3.75V
TR801 is 55mV at base, base to collector ~10V, base to emitter -55mV
TR802 is 2.3V at base, base to collector 8.3V, base to emitter -540mV
All close enough.FR801 ~4Ω (my meter can’t go lower)
FR802 218Ω
FR803 22Ω
TR801: Base ~50mV, collector 10.82V, emitter -25mVBlack meter test lead connected to chassis ground. I use one of the neg. speaker binding posts for a good ground. Then probe the Emitters, bases and collectors with the red meter lead.
FR802: +11.12V both endsWith your black meter test lead still connected to chassis ground. Probe each end of FR802 and FR803.
Apologies for the delay, was out of town all weekend.There is a pair of yellow wires coming off of the power transformer. Measure the AC voltage across these two yellow wires.
Also pull one lead of FR801 and measure the resistance across the resistor.
Need to know what the AC voltage out of the power transformers secondary winding (the two yellow wires). Put black test lead on one yellow wire and red test lead on the other yellow wire. Its AC so no polarity.simultaneously
A bit left field, are your measurements with function selector set to AUX or TUNER, try with AUX to rule out TUNER issuesFR802: +11.12V both ends
FR803: +11.12V both ends
I have had the function selector on AM this entire time, let me get these diodes back in and check those two againA bit left field, are your measurements with function selector set to AUX or TUNER, try with AUX to rule out TUNER issues
On AUX I’m reading ~10.9V all sidesA bit left field, are your measurements with function selector set to AUX or TUNER, try with AUX to rule out TUNER issues
