AC or DC?11.4V across yellow wires
Should have at least 30 vdc on the common end of each of those resistors.FR802: +11.12V both ends
FR803: +11.12V both ends
AC or DC?
Sorry to get back to you so late, I haven't checked the site in a good while. I ended up just setting this one aside while I was doing other projects.@Joolian did you manage to get this resolved?
I have just successfully recapped the power supply board on my CR-600. I have not touched the main amp board yet as best to mess with one thing at a time if possible.
I have 14.68V across my yellow transformer wires (VI) with 124 VAC coming in so 15.3V sounds fine. This goes through FR804 and then a bridge rectifier to create +12R which is not regulated. +12R measures 16.2V for me once settled after the relay clicks (all my incandescent lamps are dead).
Here are my other voltages:
+12 12.04V
+12M 11.54V
+30 29.52V
BL and BR are about + / - 38V (measure -BL, +BL, -BR, +BR separately with respect to ground)
If you look at the schematic (attached) the voltages for TR802 are labeled.
Yes, measuring across both wires. Seems strange that I'm getting ~1/2 the voltage I should be expecting from the transformer. According to my DBT it's pulling 55V in though.My bad. The VI transformer wires are indeed purple and that is where I measured the 14.68V AC.
Across the yellow (YE) transformer wires I measure 36.12V AC.
Just to clarify you are measuring across both yellow wires when you get 15.3V AC and not from one yellow wire to ground?
Medium glow on a 60W bulb (highest I can find). It's not glowing nearly as bright as it was when I was working on my Kenwood KA-3500 and since it's actually giving me a voltage reading and not 0L I assumed the glow was a mix of using a 60W bulb for a higher power receiver, but I will do some poking around for a short.Well that would explain it. I am getting 36.12V from 124V mains. At 55V I would be seeing 55 / (124 / 36.12) = 16V
I assume your bulb has a medium glow since it is taking more than half of the voltage? If so you need to get to the bottom of this first.
FYI with a healthy power supply on a 75W dim bulb I am seeing about 32V across the yellow wires.
Get one of these and use a 40 watt and or another 60 watt.Medium glow on a 60W bulb (highest I can find). It's not glowing nearly as bright as it was when I was working on my Kenwood KA-3500 and since it's actually giving me a voltage reading and not 0L I assumed the glow was a mix of using a 60W bulb for a higher power receiver, but I will do some poking around for a short.
All 4 pots for bias and offset have no effect from being turned. Considering I'm sitting at about half voltage from the DBT I think my power supply voltages look okay, so would I be correct in thinking that it's something towards the "front"/input of the main board since it's effecting both channels' bias and offset?So with the equivalent of a 100W bulb the tuner is only seeing 62V. It is not time to come off the DBT yet...
Not sure what is up with your bias but even at a lower voltage your left channel is too high (should be 0.023 ±0.005V). Are you saying turning VR703 / VR704 has no effect?
Only common circuitry is the power supply!All 4 pots for bias and offset have no effect from being turned. Considering I'm sitting at about half voltage from the DBT I think my power supply voltages look okay, so would I be correct in thinking that it's something towards the "front"/input of the main board since it's effecting both channels' bias and offset?
This needs attention. It is very likely your whole problem.I will note that the emitter of TR802 started out around 4-5V and took a while to climb up to 14V.
Needs to be a stable 30v DC. This is the power supply for the pre-amp and EQ circuits.This needs attention. It is very likely your whole problem
How would I go about testing a zener with a DMM?This needs attention. It is very likely your whole problem.
Possible casualties
TR802
TR804
D806 -- 31v Zener *
C814 -815 *
R806,807 & 809
The dim bulb exaggerates the issue.
