Only cosmetic differences between them, under the skin they're the same amp.Seem there is a little bit different between PC5002M & 101M.....![]()
Hi Mark B sir,
Thank you for your information!! :thmbsp:
Do you know how to change it to 220v ?
THX
don't believe this is possible. pretty sure the transformers don't have the extra windings. and unfortunately, unless i've misread on the step-down transformer, i can't imagine you can find an adequate one for this amp, unless you find a giant one from a hospital or a physics lab (remember, the amp is fully capable of drawing 30 amps of current). your best bet is probably to get an electrician to put a 110V line in, if the european (or wherever) system is set up to allow that. what is your situation? do you have a line on a 101M or PC5002M?
sunboy's asking about making a 110V amp work on 220V, which means a step-down is needed, at least from the amp's perspective. but it seems like a step-down transformer can become a step-up transformer just by flipping the leads around - is this right?
so with the 4x rule of thumb, you'd want something like a 6kW transformer? can't remember what the amp says on the back, but 1.5kW seems like a reasonable number since we can do 750W RMS stereo @ 4 ohms. i don't know how efficiency factors into those power rating labels...
Cool, AK member Arkay lives there too.Hong Kong![]()
The MX-10000 sounds a bit better to me, and the bass is tighter with more slam. Of all the amps I've heard I think that the PC5002M comes closest to the MX-10000.Hi Mark B,
Thank you for your information again !!
Now, i just use one ISOCLEAN POWER transformer for 101m
How about your PC5002M compare with MX-10000 ??
Hi theophile,
"Can you go active with the JBLs? "
No......because i don't have any crossover gear on hand
By the way, you have an awesome system. How about starting a thread with pics and descriptions of your gear?
No.So, you sold out the PC5002M already ??
