lJelal
Member
I have acquired a PX-2 which is in very good shape except the arm left / right movement was, of course, stalling. I flipped & reversed the arm belts. I also tried to add a bit more tension & grip by placing a rubber piece (see Motor Belts image) on the motor. The previous owner apparently tried to fix the problem by adding another belt.
After putting everything back together, the arm moves up & down with buttons, but neither auto nor manual left / right movement of the arm works. Manually turning the motor wheel moves the arm fine. Please advise on best approach for troubleshooting. Also, please check the purple pointers. The yellow stuff looks out of place to me.
