Yamaha PX-2 - Starting My Journey
The shaft looks solid as it turns. No wavering visible to the eye.
This does look like play in the platter to me.
Yes, and that play would have to be in the motor/shaft since you are not rocking the platter itself.
You might remove the platter, rotate is some and reinstall. Keep trying this until you reach a spot where all is well or you have gone 360. I have read of a Thorens which was cured tis way.
I did try this, but i could not find any spot where it made a difference.
Can you please remove the platter, start the motor by pushing the < button and then just letting it sit there spinning. Now, take a short video of the spindle and let us see what that looks like. This may provide more/better information upon which to diagnose what is going on.
Perhaps also pile something up beside it and lay a scribe across that barely touches the top o the spindle. This will make clear how much deflection there is and is it always at the same point of rotation.
Can't see any wobble, but due to the geometry, any runout in the shaft is probably multiplied tenfold or perhaps much more.
Can you put something up to it that is sharp edged and keep it steady. A small carpenter's square comes to mind, and put a spacer under the far end to get the side by the spindle nearly parallel to the brass (Morse?) taper and very close, a couple thousands of an inch. You could put a Trump-mark (sharpie line) on it to get aware of where in rotation the runout is if there is.
It's much easier to see any variance when the window is real small.
If there is no detectable runout, try greasing the taper and, with the motor not running, rotate the platter with a similar runout gauge to see if it's in the platter.
(that's unlikely but possible I guess)
But now, I'm recalling that you were able to rock the spindle shaft in the motor housing. If that's the case I hunch the motor's somehow worn.
Another view
I see a small amount of undulation in the gap but I don't know if it is plausible that this would translate to the amount of platter movement seen - need the experts to weigh in.
If the spindle is bent, that would translate to a much larger up and down movement at the edge of the platter. Can you post a video of that? Maybe with a reference close to it.
Billwojo
I went searching deeper... I found some interesting things...
I seem to have a missing washer. I was very careful removing. I don't think I lost it myself. The plastic feels quite brittle on the remaining 2. Will replace all 3.
I have a broken BMC plinth prong. I don't think anything can be done about that.
I also feel like the spindle needs lubrication to be able to turn more freely, but I have no idea how to get in there to lubricate it.
Looking at the bottom of the platter - I see some suspicious things.
There are 4 circular indentions with scratches over them & one circular protrusion that is partially smoothed. Also next to the protrusion, it is beveled near the finger hole. Is this normal? I was wondering if these are platter defects that could be causing the wobble.
Think those are cast mark positions, for Yamaha to balance the platter at the factory assembly line.
The washers are just for keeping distance between the pcb and the motor. To lubricate the bearing just pull the shaft (spindle) out of the bearing. The sound when turning the motor by hand is not normal.
I've had a Yamaha PX-3 rotting away in my closet for over 20 years. Could be more. Only problem was when started the tonearm had to have a slight nudge to go to the record. I finally sent it off to the Professor for a total fix. I contacted him 7 months ago and he told me he was swamped and get back to him in 3 months. This time he is taking it in. I just saw one sell for 1300$ on Ebay for parts. It wasn't tested but the seller thought it was old new stock. I will let you guys know how it comes out when it is done. It will be months.20210925_132904.jpg 20210925_163326.jpg 20210925_132812.jpg
He's going to fix the feet too. The rubber just rotted out and the spring and bolt are not held in place anymore.
I just got my tonearm for my PX-2 back from Professor Bizzt and everything is operating properly. It's nice to have the old girl up and running again. Bought it new in 81.
I inherited mine from a younger brother in law that overdosed. Sad. He got into a car accident and sued the insurance company. They gave him a fat check and he bought a killer system. His leg got messed up and he took painkillers for a while, and with all that money he got cocaine too. So he mixed codeine, and coke, and alcohol. That was it. He used the TT for about 2 months before he passed. His parents didn't listen to music so they told me to take it. I used it for about 5 months and got into CDs. Then it went into storage for ever.
I'm glad you are happy with the Professor's work. We are lucky that someone is still around that knows how to fix these TTs.
I just got an email from Alan because his address is posted on the Webstore and he is freaking out about it. I shipped the TT yesterday and it should be there by Thursday.
Enjoy the machine!!
Enjoy the machine!!
Freaking out ? Alan ?:) It's a Hell of a thing to ship, isn't it ?
