Easier to attach the photo than to type
If you measure this, add pin 6 to the list. So, pins 6, 9, 10, and 11. This would be across 100k resistors R48, R49, R50, and R51.I would like to know resistance (with power off) between chassis gnd and each of ic 7 and ic 8 pins 9, 10, and 11.
GND to IC7, IC8If you measure this, add pin 6 to the list. So, pins 6, 9, 10, and 11. This would be across 100k resistors R48, R49, R50, and R51.
Pin 6 is not connected to an ic 6 output like the others are. Also interesting how different the pin 11 number is from nominally identical pins 9 and 10. I think those numbers point somewhat towards a problem with ic 6 but not definitely so.GND to IC7, IC8
p6 = 100k 100k;
p9 = 3.5k 3.45k;
p10 = 5.5k 5.6k;
p11 = 15.9k 16k;
The point to removing IC6 would be to see if the voltages on those solder blobs/pins normalized so could conclude IC4 is working ok and confirm something (IC6 internals?) is dragging down the voltages.What would happen if it is removed? No voltages to IC7,8 and as a result no signals sent to the pre-amp,
Don't know the amp, suspect that there is always one source selected, problem is the IC4/IC6 interface is not working as expected with some voltages not meeting the high or low threshold.ask if there is a "default" state/connection for IC7,8?
