If you measured those voltages directly at the volume control, then the problem is upstream of that. So, either at the upstream part of the CD direct switch or at the mux ic. Follow the signal voltage upstream through the switch.Vol ctrl in CD Direct mode: min=0.001 V, max up to 0.250 V and it varies.
in CD mode: min=0.001 V, max=0.009 V and it stays on that.
Yes this needs to be clarified, if it's music then we can see the fluctuation in the voltages at pin 14. can you use a tone generator app from your phone to connect to the inputs?Do you have stable DC voltages (relative to gnd) on ic 7,8 power and control pins (6 through 11, and 16) that agree with the voltages in the schematic?
What do you have connected to the CD rca input?
Measure the voltages on IC 6 , the 8.2 volts for pin 11 should come from IC 6 pin 13.A CD player is on CD rca input.
No, the DC voltages on pins 9,10,11 are messed up. Should be p9: 0, p10: 0, p11: 8.2V.
IC7. p16 : 9.4V, p6 : 85mV, p7 : -9.4V, p8 : 0.4mV, p9 : 1.35V, pin10 : 1.33V, pin11 : 1.1V.
IC8. p16 : 9.4V, p6 : 85mV, p7 : -9.4V, p8 : 0.4mV, p9 : 0V, p10 : 0.6mV, p11 : 1.15V.
Yes, I can. The fluctuation is fine, I am not happy with the voltage being the same on p3.Yes this needs to be clarified, if it's music then we can see the fluctuation in the voltages at pin 14. can you use a tone generator app from your phone to connect to the inputs?
p13: 1.15V should be 8.2VMeasure the voltages on IC 6 , the 8.2 volts for pin 11 should come from IC 6 pin 13.
Yeah , some are also off and come from IC4 . Lots of voltages on that chip.IC6.
p2: 2.95, p4: 1.85, p8: 9.4
p9: -9.4, p13: 1.15, p15: 0.68, p16: -0.5
Hmm, make me wonder if IC 6 is also bad.
Yeah, maybe IC6 or maybe bs in bs out. Pin 4 looks like the issue, datasheet shows a high input as +2.2V.IC6.
The outputs of ic 6 only "pull up". For 0v input, the voltage at the output is determined by the voltage to which an external resistor pulls them down.The guiding(?) voltages on IC6 are a bit misleading, pins 1&16 ...6&11 are the same equivalent circuit so how is it possible to get different results for 0V input...
