Yeah, I think so. First sort out power supply, look at right channel later.These've been replaced IC7, IC8, D15, C164.
What's next? Power up with DBT? The Right ch power still disconnected by the lifted legs of the jumpers J51 J121.
Means D15 is working and you have +/-12Vdc on each rail, probably ok since on DBTmeasured directly between + and - gives me 24 Vdc.
What are you using as GND? I like using any black speaker connector, provides quick/easy/reliable connectionVdc on + and - is almost 0. Measured as in #138.
Confirm "D15" power supply, measure Vdc at Q36e, repeat at Q37e expect +/-9.4VdcWhat's our next step?
I'm assuming DBT is bright, the right channel short is dragging down the power supply to both channelsAfter jumpers reinstalled Q26e and Q26c does not go above 2.4 mV.
Neither does the equivalent for the L channel Q25. Both Q26 and Q25 show the same results.
Gotta light?edit need to step out.
Q102 e: 2mV; c: 2.5mV; b: 0.3mV;
Q104 e: 2mv; c: -1.6mV; b: 0.2mV;
Q28 b: -2.5mV; c: 3.5mV; e: 0.4mV;
Q30 b: -2.5mV; c: -3.5mV; e: 28mV;
Odd that Q30e is the high point and +ve voltage, probably indicates solder bridge.Q30e: +25mV to +5mV
