Probably the (partially) burned fuse resistor limited the current to the LED. But the burned 4051 suggests that the downstream DC supply was affected.I remember it was mentioned in one of the threads that the bulb requires 14V. I used a 12V LED not in series with a resistor and actually it did not die as such. It dimmed out, yes - but later on in a few days I connected it to an external power and it brightened up. After the first try of the LED I never connected anything to the unit again.
Should I also test the pins 7-11 on the power board? I thought that the initial check of the unit has to use the relay to supply 120V to the main transformer, providing no problems are found. Otherwise those pins have no power by design. And we have not found out the reason why it doesn't pass the initial check.The fuse resistors there were checked/replaced. But I don't see that the DC supply that derives from the same secondary winding as powers the bulb with AC was verified to be working afterwards.
Maybe measure (Vac) the lot,Which are the other ones you wanted to see?
You're gutsy !!! There could be DC on those outputs. Hope they were throw away speakers.between 7 & 11 (unregulated supply) : 71 Vac
between 8 & 10 (+/-9V supply) : 23.8 Vac
between 9 & 10 (lamps) : 12 Vac
Just a remark, I connected the speakers and a CD player through the RCA source currently selected. There was no music coming out of the speakers, but there was some noise and crackling sound from the left speaker only. Both of which are expected as there's no power provided to the R-channel and the IC7 removed.
Voltages are in the ballpark, were these on DBT, expect yesbetween 7 & 11 (unregulated supply) : 71 Vac
Yep, I believe thats what he means.Yes, the above voltages were taken with the unit on dbt.
Measure Vdc between the J108 (that leads to Q36e) and the chassis (GND), right?
Vdc between the J108 (that leads to Q36e) and the chassis (GND) is only 2 mVdc
Try that, 2mV is not ok, maybe I got the wrong jumper???I can also check it on pin16 on the IC7 socket and GND, correct?
