Yet another AR XA rebuild thread
Your wiring configuration (in post 90) is different that what is done on US models. Green and the top white is summed. Top when the motor in in correct position. Here is a diagram...
Someone else please jump in if I am incorrect.
I found the service manual that shows the wiring for 220V. Unfortunately the motor still gets burning hot. I will have to put this motor a side and continue my build with another motor.
Just an update for the record. I did compare my hot motor with two other motors running on 230V / 50Hz and they all running hot. When the motor is mounted on the top plate the heat is distributed and I'm guessing this is just the way it is. Any ways, I have assembled every thing and tested everything for 50h+ and it works just fine. I'm done with my build and will post pictures shortly.
