Here's the first filter section. Since the original can caps are just for appearance, the first filter section (before the choke) is a 4uF 600VDC oil filled cap with a 1M bleeder and a .01Uf 1kv bypass cap.
Why a 4uF cap? Two reasons: 1) Heath ran the daylights out of the output tubes and today's higher line voltages are a sure-fire recipe for shortened output tube life. The 4uF input cap to the choke will knock a few volts off of the B+ and get it down to about where it should be. 2) The power transformers on the W5Ms have a reputation of being somewhat fragile on the high voltage windings. Couple that with the quick warm-up characteristic of the 5R4 rectifier trying to feed a large capacitor load at start up, and you get the idea.
Of course, surgistors will also be added in series with the AC input on the primary side of the power transformer.
Well, there's the undersized 6V6-sized OPTs in some versions---.
Yeah, you could call it that or you could call it "tuning" the Pi filter section for the output wanted.
I like "tuning" much better! Does this compromise regulation in any way?
I'm following this with great interest. Would I be advised to let the thread play out before buying parts? It seems you have this pretty well dialed in as far as improvements and component value changes are concerned. I can do the cosmetics in the meantime.
Br1ck, you don't have to powder coat it. I have had good luck painting Dynaco chassis with Rust Oleum Hammertone.
Another thing to think about...I'm not familiar with these amps but on a Dynaco ST70, I like to make the power cord hole bigger for a IEC receptacle, drill holes for bias test jacks and holes for neutrik connectors on the front prior to painting.
I just got done sanding down and priming the power transformers and likewise there was rust underneath the paint. As I suspected, these are very early production W5Ms. There is no surgistor, or any of the other later changes Heath made during the production run. In fact, both power transformers are date coded for the 34th week of 1954. Since Heath introduced the amp in 1955, it makes sense.
One of these days I'm gonna do an amp in John Deere colors.....just because!
