BrassTeacher
Uncurable Tweaker
I misread CY series caps as series connected. Sorry
Don't apologize, because you called it on the swapped plate leads!
I went out to eat to take a break (Waffle House), and while I was sitting there, I kept going through the schematic in my head. In the schematic I drew, no error is obvious. On the original schematic, the inverted signal coming off the anode of the voltage amp tube is fed into the 6V6 connected to the brown transformer lead, and the signal coming off the plate of the inverter is fed into the 6V6 with the blue lead. The feedback loop is connected to the cathode end of the voltage amp:
Here is where I screwed up: I forgot that the signal going into the cathodyne was already inverted. So, the signal coming off the anode of the cathodyne was the natural polarity, since it was re-inverted, and the signal off the cathode end was inverted. So, the way I had it hooked up the first time, the feedback was entirely positive instead of negative. I had fed the inverted signal into the blue-leaded 6V6, when I should've fed it into the 6V6 with the brown lead. Oops.
Luckily it was an easy fix, and took less than 5 minutes:
Thanks for the tip grndfix!
Now all I need to do is silence the hum.
Since that pushes the voltage differential from heater to cathode close to the absolute limit, I figured I may have found a big part of my problem.
