Ok, yes, I said I'd move on in the above post, but today I decided to try a
good pair of closely-matched smooth-plate Telefunken 12AX7 (that I found messing around in the workshop yesterday). The results were better than the generic 12AX7 that I had in the amp, but not Earth-shattering. A little more clarity was evident though. One of my test tracks is the "Glory Days" track on the soundtrack to "The Incredibles". Played back on the computer from a non-compressed .aif file ripped bit-for-bit from the CD. One of the things I listen for has been missing on this amp, and that is a soft ride cymbal part that happens the first time the dynamic levels drop in the track (first time it gets softer). It still wasn't there on the Telefunkens. I figured it was time for me to resurrect my battery-powered preamp and try playing it through that. I assumed the level of drive at the low-end of the dynamic spectrum just wasn't enough from computer to input tube.
Then, I looked up at a pair of generic 12AT7 I had sitting on a shelf in the living room. Many years ago, I built a preamp based on a 12AX7 that sounded
much better when I tried a 12AT7 in it. I thought, "Hmm, I wonder...". So, in the generic 12AT7 went (Ok, one was a Mullard, but it was horribly unbalanced. The other I believe was an RCA, the label had worn off but the tube number looked like RCA's mark).
The less-than-ideal12AT7s in this circuit absolutely
SMOKED the good pair of Telefunken 12AX7. Like not even close. The effect was if I had been listening in the kitchen, then suddenly walked into the living room where the speakers are (There's no door between the two).
All of a sudden, my missing ride cymbal part was there, as well as a few other high-pitched percussion parts. So, out came the good pair of balanced Telefunken 12AT7 that I had on hand. Ride cymbal part was still there, but you could hear the musical shape better, since it was not played every note the same volume. I heard a few electric bass lines I had been missing, and you could hear the musicianship and style of all the musicians much better. It was totally missing with any version of 12AX7, I just hadn't noticed until the 12AT7 swap. Instead of hearing a really good lead trumpet player, you can tell that it is definitely Wayne Bergeron. He has a distinctive sound in the upper range.
So, long story short, give up on 12AX7 in this circuit. Get a good pair of 12AT7. Trust me.
Lastly, on today's episode of "It's Enough to Make a Grown Man Cry", we have this:
Pretty, aren't they? They appeared to have little to no use. After the success of 12AT7 in the amp, I started testing all the 12AT7 I had. These are all, of course, Amperex made by Mullard. They are
ALL basically dead.
. The best single triode measured 2900 (new is 4000 on the 800A), which isn't horrible, but the other side was 1200. All the other individual triodes came in between 1100 and 900
. Yes, tubes tested before and after had quite a few in the 3800/4000 range. I was so disgusted I didn't even put them back in their boxes, I'll use the boxes for other tubes that don't have them.
