Finished and tested today.
And your experience thus far?Finished and tested today.
I built one crossover ( loosely) for testing purposes... I'm finding in my speaker which is a 19 clone but I'm using a JBL 2231 woofer and a BnC compression driver (250d) 8ohm.
The bottom end sounds great but I seem a bit rolled off on top, I'm guessing that's due to my 8 ohm tweeter?? Anyway, I copied Zonkers diagram , which values would I tweak to up the high end? Looks to drop at around 8000 Hz.
I'll look over my mess. Thanks! Yes the drivers are real B and C. What's the thought on break in time here?? I've got maybe 10 to 15 minutes onlyThe Z19 was prototyped with the 8ohm B&C 250 driver on a 511a horn ( therefore your "guess" about the 8 ohm impedance of the driver being a problem is right out the window ).
You shouldn't really have any HF problems with a bonafide B&C 250 on that big radial horn you're using ( assuming your B&C driver is healthy ).
- You are using real B&C de250's right ??
You might want to double-check your Z19 parts-wiring ( for a mis-wire in the LP2 section ).
L3 + C5 ( along with LP2 ) create a HF roll-off ( the roll-off occurs when LP2 is not cranked wide-open ).
- I'm thinking that a backwards wired LPad ( LP2 ) might display the symptoms that your describing.
You can reduce resistor R7 from 3R down to as little as "not present + totally shorted" to get more overall horn-driver level.
I would have thought the crossover was designed for a Altec 801/901 driver?
I thought Jeff Markwart crossovers were crossed higher?? 1600hz or so?Break-in for HF diaphragms "might" effect the lower frequencies if the suspension were to actually loosen up some.
This hasn't been documented as happening.
HF won't magically appear due to a looser suspension.
The Z19 is an Altec network design ( though obscure ) that was used with the Altec 604-8H duplex ( the workings of this network were first committed to paper by Jeff Markwart and Jim Easley (??) and published in Jeffs Markwart corner website > which is now gone ).
Yes... That's right.![]()
Looks like @ 1200hz to these eyes.
Thanks! I've done #2 and can't quite get a balance that satisfies...You have 2 or 3 pretty simple options.
#1) Increase the value of R7 by an extra 1 to 4 ohms ( that'll decrease the overall horn level ).
#2) Roll of more HF//UHF ( using LP2 as it's currently wired up ) as well as pull down the midrange on the horn by adjusting LP1 ( which is setup to suckout the midrange ).
- Balance to taste.
#3) Remove L3 and C5 from the circuit and then reconnect LP2 to act as an over all level control for the horn circuit ( rather than acting as an HF//UHF roll-off control ).
