Even Magnavox used BSRs in their crappy particle board and plastic last-gasp consoles. I had one here not that long ago. How the mighty had fallen.....^ yep, sure looks like a BSR changer to me. It made me wonder too so I looked it up. Apparently Zenith used BSR changers quite often. Who would have guessed...
They did most of the time. I'm not exactly sure when, but from what I've seen, it seems like early to mid 70s is when they started using BSRs too.Didn't Zenith usually use V-M except the TOTL where/when they used the inhouse model ?
They were pretty neat. I had two consoles with those changers over the years. One was old enough that it still had the cobra tonearm and the other had the slim tubular tonearm and 2g cartridge.I always thought their built inhouse changer was really cool. When I was a kid, a friends parents had a Zenith console stereo. The changer was older but I remember the built in 45 rpm stacker spindle. That was something as some many stacker spindles that you slid onto the regular spindle made noise or affected wow and flutter.
Really. Ugh. I liked Collaro(used by Magnavox). Didn't Zenith usually use V-M except the TOTL where/when they used the inhouse model ?
Built inhouse best Zenith changer:
That's a Tetrad cartridge. VERY popular on BSRs, and other record changers.
Looks like it's played a few dusty records too.![]()
1964??
Now THAT looks like a nice changer! Nice diet that Zenith put that changer on. Slim and light weight.
Compare to the 1964 Garrard Model 50:
It's probably just the picture. It looks OK to me.Is that thing mounted right ? Or left ? LOL. Doesn't look centered at all.
There were good and bad models from BSR, Garrard, etc.
The last BSR I worked on was one of the later cheapies with the plastic platter. It was a total piece of ****. It ran way fast, and the WOW and flutter were off the charts. I've had others with steel platters, and they were OK. The upscale models with alloy platters, A/S, and MM cartridges are supposed to be fairly competent.
I had a Garrard 40B, and it was decent for a low end machine. Easy to service, too. I had a Model 70, and it looked nice, like it should have been fairly good, but it was a piece of junk. I could not make the auto mechanism behave, and I scrapped it. There are other Garrards that are known to be crap and a pain to service. Maybe that was one of them? I am not an expert on them.
Going by the few I have messed with, Magnavox / Collaro seemed to be decent and not too hard to work on.
