my head spins with all the options before me. I just want to raise my hf volume. Please somebody....
You are using an
Altec 414, right?
If so, and if your compression driver is an 8 ohm unit, use these values:
R1 = 16 ohms
R2 = 16 ohms
C3 = 0.47uF
If your compression driver is a 16 ohm unit, use these values:
R1 = 50 ohms
R2 = 16 ohms
C3 = 0.33uF
No L-Pad
For 16 ohm resistors R1 and R2, use four Dayton 16 ohm resistors connected in series/parallel. If you need to use a 50 ohm resistor R1 for a 16 ohm compression driver, use four 12.5 ohm resistors in series.
The Parts Express part number for the 16 ohm resistors is
004-16. Order 16 of them if you're building a pair of speakers with 8 ohm compression drivers. The 12.5 ohm resistors are part number
004-12.5. If you're building speakers with 16 ohm compression drivers, get eight 16 ohm resistors and eight 12.5 ohm resistors. Either way, it will cost less than ten bucks and they'll be delivered in just a few days.
While you're there, get a pair of the 100 watt resistors for the Zobels, part number
019-020. They're about ten bucks each.
When you study the circuit and see the power dissipated in the Zobel resistor, you'll understand why I suggest a 100 watt part in that position. See page 66 of my
Crossover Document. The Zobel resistor receives about 1/3 the input power, so a 10 watt part will be exceeded when the loudspeaker is presented about 9 volts at its input terminals, 30 watts across an 8 ohm load.
