A25 replacement woofer- here are the details-
SEAS Prestige 25F-EW (H0085) 10" Paper Cone (Dynaco A25 Replacement)
http://www.madisound.com/catalog/product_info.php?products_id=817
'... very nice roll off on the top end...'- part of quote from Madisound.
Yes, superfluous information- 'seperate' implying that the experiment will be dead easy, as I already have the X/O in two sections (as if for biamping)
Have 8.2 uF, 12uF and 15uF to try in the zobel.
EDIT- Looks as though I was a bit hasty in posting the Madisound info.
From classic speaker pages:
http://www.classicspeakerpages.net/IP.Board/index.php?showtopic=3901Pete B suggests that the Madisound replacement is a differently constructed, more efficient version from the early A25, which may explain the difference in bass response you measured.
Measured T&S parameters (
from above link, post #3- pete b)
SEAS 25 TV-EW UNIT SAMPLE: PLB#1 1/12/06
UNIT DATE: 25 week of 1971
Rubber surround part number: SR 231/1
Effective cone diameter = 21 cm measured
Effective cone area = 285 cm^2 old SEAS spec, 350 cm^2 new
(25F-EW)
seems the old spec of 285 cm^2 was an error and might explain
the difference in moving mass below:
Measured SEAS
Delta M 15.75 Spec
Fshift -16%
Fs 23.6 20-25
Vas 205
Re 5.7
Qe .48
Qm 4.2
Mms 37.5 30
no .36
SPLref 87.6 88
Bl 6.6 .8
Qts .43
Cms .
I thought it would be interesting to hear what effect the implementation of E/W has on the imaging that the A25 is known for. Unfortunately, no facilities to MEASURE yet, just arbitrary opinions
