Thanks for the ideas, (the additional cab is 2.2 ft3 with no bracing, 26" tall)
What I'm trying to understand here is, do some have issues with this height
just because it's BIG? Thinking it's bigger then something they want to move
or just have in there space?
Because I don't find it objectionally large nor really that big, I stand next to
it and I'm darn near 2 feet taller, it's fairly skinny and only 3.5 ft3, if I brace
it well could end up with less then 3.5 ft3 actually.
Yah it would suck to stow them away, but I plan on using them and have a
place they would fit no problem.
And I am not really sure that with a tweet mounted in the cab I would want
it any lower then it would be, it is right at ear height. If the tweet cab were
seperate and on top then I wouldn't want it that high but with it in there?
No I wish I did have another or 2 S99 cabs, these the only ones I have, went
through bunch of cabs yesterday an actually tossed couple bad apples finally.:thmbsp:
(Andy would be proud)
I really don't have a problem with the cab this size, is there any technical issues?
Also in winter I don't really have access to a place I can build boxes from scratch,
but I can take some prebuilt ones an modify them without to much problem though. :thmbsp:
Kegger,
How big are the lower pair of speakers? They might be large enough to use as-is, just transplanting the LE14a and WG into it - preserving the S99s for a more suitable 10" or 12" woofer rebuild? If the volume needs expanding a short base could be added to it, opened into the bottom of the cabinet - a 6 inch base slightly smaller than the width and depth might add a third of cubic foot, and raise the speaker a bit. It could then be made of MDF painted black, and look like it was 'stock'.
Or, is there any chance of getting a 3rd S99 cabinet? You could then do what Zilch did in his S99 'tall-boy' rebuild, but using a single S99 cut in half to extend the cabinet height. You'd go from about 1.6 to 2.2 cubic feet, and get the ports on the bottom and preserve the walnut look. Or using 2 extra S99s they could be cut at about 3/4 height and maybe get you to 2.5 cubic feet when spliced together. just ideas you probably thought about already...
