I'm workin' on some 301s, actually.A great speaker is now awesome.
You guys a gettin' good at this stuff:
D220Ti nominal sensitivity = 109 dB, less 20 dB = 89 dB. The Advent and DC250-8 woofers are ~4 dB less than that due to my dorking with the lowpass to bring up the bass response, Baffle Step Compensation, some would call that; they balance with the additional L-pad set at midpoint, i.e., -4 dB, for a system net 85 dB sensitivity.
That's my guess, and I'm sticking to it.
The baffle step slope begins at ~7.1 kHz, the wavelength of which is ~1.75". Doesn't make sense to me, either, but that's what I believe it shows....
2 cuft is too small. I like it just fine. :thmbsp:
Gordon says try the 12" Dayton Classic.... :yes:
Yeah, me too, and I also have experience with quite a few different type of horns as well. This inexpensive wg blew me away. While I am not going away from the old horn stuff just yet, I know I'll be listening to the EWG for a while.
Congratulations, they are beautiful!
With great E"Wave imaging, and proper toe in, no center ch. will be needed.
Wow those look great and you work fast! What cabinets are they? You should have mentioned you were looking for Ikea legs, I have a set of those as well. I also like your SX-1250.
Can you define "sound good". Zilch usually expects a bit more of a description than that.![]()
Internal volume ~4.7 cubic ft. Ducts are 2 inch diameter by 2.5 inch length. I have a brace across the back panel to stiffen it up, and considered adding a front to back brace. I chose not to for now, the cabs seem pretty solid as is.
As for polarity, all seems OK. Positive +1.5 volts at input terminals moves both woofers forward. I tried to make sure the polarity was good when I put these together because of the LE14 +/- mislabeling.
Don't get me wrong... these guys have bass, but I think need could use a couple dB extra added at the low end to match some of my other speaks. I don't have a way to measure thse directly, but I do have some Wharfedales spec'ed -6db @28 Hz that seem to push the low end better.
Just got a line on some 501's would they make a good candidate, do the woofers crossover high enough?
OOOOHH, "Constant Reflectivity", man now that would be an experience, sounds like 1 giant echo. :thmbsp:
(or, the sound of 2 speakers clapping)![]()
I will be receiving some ADS woofers soon (from L730), and will give one a shot in one of the L56 cabinets to compare. According to Kegger's measurements, should I try to bump up the impedance from 4-6 Ohm to 6-8? Would a 45 Ohm resister in parallel (as Kegger used for two woofers) with the positive woofer lead work in this case? Would going without added resistance be "wrong?"
Thanks, Ewave gurus!:thmbsp:
Solid state's not going to care.And thanks, Z. I saw that -- just wondered about what ill effects the mismatch would incur, theoretically.
At least he supplied the requisite beautiful pics! Good show!:thmbsp:
Russellc
