Bauhausler
Rational Subjectivist
To be more specific, 0.47 uF will give you the most boost, but you'll have to dial your adjustable toward max SPL to hear it, because the cap attenuates the midband, which must be brought back into balance with the woofer.
Actually, in this setup I don't need as much overall attenuation due to high woofer sensitivity. I settled on a fixed LPAD/compensation of 20 Ohms shunt and 8 Ohms series instead of 30 Ohms series/15 Ohms shunt. My mental estimate says the cap scales with the resistor, so I need about 2uf for the same lift across 8 Ohms as .47uf gives across 30 Ohms. .47uf is 42 Ohms at 8khz, which doesn't reduce the 8 Ohms resistor it's in parallel with at all (6.72 Ohms). 2uf is 10 Ohms at 8 KHZ, which reduces the attenuation to 4.4 Ohms, considerably more boost.
I think.
