I'm doing both.One note on the Ecowave circuit boards, use permenent 3m double sided tape, instead of a cable tie. The coil want's to slip out of the loop, and it isn't going anywhere with the 3m stuff, at least in the next 20 years.
I'm doing both.
Post some pics of your completed project, so we can make you an "Official" E'Waver, please.... :thmbsp:
I just did "medium" fill, as I recall, maybe 60%, R-13 lining the four sides, and a layer over the back to hold it all in place.... :yes:I need to read the post again via the lack of sufficient damping material, as mine are plum full of fiberglass-not much room for any more-if at all.
About the same price as new 2226 JBLs I think.
Something to consider, with options. That's an alnico magnet structure, looks like?
Hello automojo
It is so they sum properly through the crossover point. Typically if you keep them in phase you get a notch in the response where they partially cancel each other out. If you reverse them you don't get the notch and when they sum you get a nice flat curve or a bump depending on the crossover type Butterworth vs LR and so on.
Here's sim from a PT Waveguide system I made showing what happens. When you put them in phase you get a notch just like the simulation. It's a mixed 18db and 12db network. The Red is out of phase Green is in phase.
Rob![]()
Russellc:
I tried the DE250 on Wayne's 4Pi x-over and followed his polarity spec from his schematic. I had to re-check into the polarity of my woofers, then I forgot how I wired them inside the box....because they are like the 2226s in polarity (pos voltage to black terminal gives forward cone motion) I may have reversed the connections internally to make plus on the box yield forward motion. IIRC :scratch2: It's moot however because I checked it on RTA and easily saw what was what.
Soon you will do the same, LOL.
Have not tried DE250s on Econo-x-over yet.
Hello automojo
Rob![]()
I have done the same and measured a significant hump in the 2-3k range. I have measured similar results with the Econo-x-over. As an inexperienced operator of RTA equipment I am curious if anyone else has had similar results.
Russellc:
I may have; but I want to re-do them w/ new measuring system.
Waiting for mic preamp right now.
I must have posted Behringer RTA at some point, buried, long ago....
