I compared their TS parameters to all other B&C 12 inch woofers and this
particular model is the one that is best suited for use as a Hi-Fi/Stereo
woofer as its higher Qts and lower fs parameters results in better bass
extension than the other 12 inch B&C models, also they have a higher Xmax
than most other B&C 12 inch woofers (exc. the 12TBX100, which is a real
brute rated at a kilowatt rms). They would also be excellent for compact,
high power PA/Music instrument or stage monitor use (although some other
models might be a tad better for this use, but I wont go into the details).
They are sturdy speakers fer sherh, rated at 700 Watts RMS. If you add a
bit of series resistance and/or use with a SE tube amp with a few ohms Zo
(to get the Qts up to, say, ~.45 they optimize in ~4 cu ft enclosures tuned
to ~39 Hz and so go down into the upper thirties, otherwise, they optimize
in 1.81 cu ft enclosures tuned to 50.88 Hz, according to the Linear Team TS
design program, which is totally acceptable for compact PA speakers (with a
sub) or for stage monitor use or even for stereo if used with a sub or tuned
lower and equalized or whatever. Based upon my experience with other B&C
speakers my guess is that they will make excellent stereo woofers for use
with SE tube amps; efficiency is rated at 94 dB; it would be nice if the
efficiency was a bit higher.
