It's official...
Well, I'm finally into the building stage of an E-wave combo... in a BIG way.
Anime Weekend Atlanta is expanding its panel room space due to higher attendance expectations, and as such, needs a new pair of large panel-room speakers... for video, voice, music and such, in about a 10000 square foot room (about 120 feet wide and 80 feet long). So, I've got most of the parts (and am about to build the cabinets this weekend) for a DOUBLE 15 E-Wave setup. Got a pair of the Pyle PH612 horns, a pair of D220Ti's, and four good TOA 15" woofers (similar to, of all things, Radio Shack Mach 1 woofers, more than anything else, except with lighter-mass foam-edge cones)... it's going to be a 2.5 way setup, with the "helper" woofer crossed over at around 100 Hz or so. Probably will wind up around 96db sensitivity... I'm gathering parts to try both the normal E-wave and the above-95dB crossover versions, so I will be prepared, no matter which way it goes.
Cabinet is going to be around 8.2 cubic feet (4.1 per woofer), tuned into the mid-to-high-20-something Hz range, most likely. I've found that 2.5 way setups seem to like lower port tunings than the simulation programs recommend, so I'll start with a long port and trim to suit.
The dimensions will be around 49"H x 21"W x 18"D. Will put the drivers as far up on the baffle in height, as possible, so that they can "get over the crowd" better.
These speakers are slated to run off a Carvin F600 amp (300w/ch into 4 ohms, which is what it'll be with the double-woofers). Should be plenty of noise.
I'm guessing right around 120dB before clipping...
Am still wondering what color to paint these... hmmm... wonder if that gallon can of red floor enamel is still any good? That's what I used to paint the "Big Reds" before (double 18, double 6.5, Eminence APT horn tweeter)... it's held up really well, and you can't mistake them for anything else!
If I do this, I guess these will be the "Little Reds"... though, they're not exactly little!
Will post a few pics, if I get a chance, soon...
