B, here is a little trick I learned way back when I was a car audio installer. Take a scrap piece of material 3/4 thick x 1 inch wide x 8 inches long, in one end drill a hole about 1" in big enough to get a #8 drywall screw through. Now from the center of that hole measure half of the diameter of the opening you need to make and mark it. Now drill another #8 drywall screw through the material on the mark(do not drill a pilot hole). Now take the screw out and flip the scrap piece over and put the screw through the hole from the other side, this way the screw will come out at the exact point that you marked. Now mark the center point on the baffle where you want the speaker hole, using the pre drilled hole tightly screw the jig down at that point , now put the other screw in the other hole until it starts to come out the other side and touch the baffle. Now turn the jig clockwise and the tip of the screw will leave a scribe in the baffle where the hole will be, all you have to do now is keep putting the screw in more and keep turning until you get between a 1/16 and 1/8 inch deep scribe. Drill a pilot hole inside the circle big enough for you jig saw blade. The blade will automatically want to follow the scribe because there is less resistance and if you take your time you can get a really nice and clean hole. I hope this helps.
